It is currently Thu Jul 03, 2025 1:00 am
Reply to topic  [ 11 posts ]
 Prodrive Breather fell off
Post Prodrive Breather fell off
After setting up the decoys yesterday morning I was fixing to take the anchor light down when I noticed I could see the air filter on my 36 PD. I thought the outer nut had come loose but when I tried to tighten it the entire breather assembly hit the water.
The Bolt that holds the air filter and cover on broke off on the restrictor plate. I don't have a scratch on the breather cover so I dont think I hit anything.
Anyone else had this happen? About how much did it cost to fix? I super glued a bolt in the plate after I drilled out the "bolt" that was in it. Don't like the setup and want to go OEM.
Sun Jan 02, 2011 7:51 pm
Post Re: Prodrive Breather fell off
The covers are bad for falling off. Just drill ya a lil hole on each side through the cover and zip tie it.
1850 Custom Flat wit a lil B&B Fab followed by a 36 Prodrive FPR
Sun Jan 02, 2011 8:10 pm
Call your dealer. They will replace all the breather assembly parts for free. Mines fell of 2 times so far in the first 9 months.
Sun Jan 02, 2011 8:22 pm
The studs break where they pass through the mounting plate. Drill it out and replace with a 1/4" stainless bolt long enough to go through the whole assy. The constant vibration weakens the stud till it breaks off on the PDs.
18x48 Charles Leonard / 36PD
Sun Jan 02, 2011 8:25 pm
Mine did the same thing and i called and they replaced it for free. Gator-Tail
Sun Jan 02, 2011 10:52 pm
Mon Jan 03, 2011 4:46 am
Did you have to drill out the air filter plate also? The way I was looking at it the filter plate sits flush with the restrictor plate. If I was going to put a lock nut on it wouldn't I have to enlarge the hole and use a washer on the air filter plate?
Mon Jan 03, 2011 1:39 pm
I'll see if I got some pics later when I get home.
Mon Jan 03, 2011 3:41 pm
I have the OEM replacement parts if you need them (used). If you have already drilled out the carb shield, then put a high grade screw in it (metric) so it won't break off again. Then put some aircraft gasket sealer on the threads so it won't vibrate off.
Mon Jan 03, 2011 8:03 pm
Thu Jan 06, 2011 10:23 am
FYI..if it breaks off again dont let off the gass to soon...your filter will fall off once the suction is lost. Dont ask how i know.[/quote]
:lol: Seen it a few times!
Fri Jan 07, 2011 9:48 am
Users browsing this forum: Majestic-12 [Bot] and 123 guests
cron
