It is currently Tue Jul 01, 2025 8:46 pm
Reply to topic  [ 24 posts ]
 continued problems.
Post continued problems.
I posted a while back about having problems with my engine killing when i would put it in gear. Well i was told that the govern was the problem and it turns out that it wasnt. Then i was told that a mikuni would fix my problems. So i got a mikuni and now it idles in start, but once i put it in gear it kills. Any suggestions?
37EFI GTR 1754 GT
Tue Jan 25, 2011 7:16 pm
Post Re: continued problems.
What kind of motor is it
Tue Jan 25, 2011 7:21 pm
35 gator tail. vanguard
37EFI GTR 1754 GT
Tue Jan 25, 2011 7:22 pm
Do you have good throttle range when in neutral?
Put yer face in the myrtles.
Tue Jan 25, 2011 7:23 pm
yes.
37EFI GTR 1754 GT
Tue Jan 25, 2011 8:16 pm
Does it immediately die or does it bog down first? Are we talkin open water or in mud? If it's clear water & dies as soon as clutch is engaged, it sounds like a short in the wiring at the clutch switch or clutch breaker. Hard to say with limited info on it.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Tue Jan 25, 2011 9:35 pm
It takes just a couple seconds to kill. But i have to give it gas as soon as i put it in gear. This happens in open water and in mud. just not out of the water.
37EFI GTR 1754 GT
Tue Jan 25, 2011 9:55 pm
if it will stay runnin by givin it gas, it aint an elelctrical short.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Tue Jan 25, 2011 9:59 pm
I HAD A SIMILAR PROB.
brought it to 2 briggs shops,wasted money and time.
finally brought it to hoyt.
hoyt set the coil gap and changed the plugs,thought he fixed it,didnt charge anything told me to get out of here.
got home,loaded boat still wont run rite.run fine in neutral,in gear,no good.more wasted time.
found the prob.myself:
wires for clutch switch melted to wires for emergency kill switch.(just making contact)
wrapped wires with tape and bent them where they aint touching no mo.
good to go.
Wed Jan 26, 2011 5:13 am
CHECK THE WIRES UNDER THE FWD PLASTIC COVER(SWITCHES) AND THANK ME LATER.
Wed Jan 26, 2011 5:16 am
sounds good. i will look under the cover and wrap them all in tape and see if that fixes my problem. thanks!
37EFI GTR 1754 GT
Wed Jan 26, 2011 10:16 am
Wrapped up both the start/forward wires and the trim wires. Problem continues. Any more ideas?
37EFI GTR 1754 GT
Sun Jan 30, 2011 8:33 pm
Sun Jan 30, 2011 8:40 pm
Profile YIM
I am idling at about 1250 rpms. Then I engage into forward and it's steadily drops to about 800 then continues to decrease until it kills. The only way it stays running, is if I am on the throttle and keep it above about 1500.
37EFI GTR 1754 GT
Sun Jan 30, 2011 9:49 pm
Sun Jan 30, 2011 9:54 pm
Profile YIM
Can ya get it to run & get up on plane?
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sun Jan 30, 2011 10:00 pm
i could be waay off, but it sounds to me like something is putting the drivetrain in a bind. bad bearing maybe?
Sun Jan 30, 2011 10:05 pm
the wire with diodes was burnt on mine,also i may have changed out a coil for nothing.
if you are running on both cyls.then
open the valve covers,check it out in there,they should be set at 5 thousnths,thats where hoyt looked first.
Mon Jan 31, 2011 12:09 am
I'm thinkin either bad diodes or a leaking valve.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Mon Jan 31, 2011 5:30 am
the wire between the two coils is the one with the diodes,in case you didnt know.
like stated above,gots to be that or valve.
diode wire is a verry easy & cheap fix.
Mon Jan 31, 2011 6:47 am
Yes, there is no problem with it at wide open throttle. Once I get it up, it runs.
37EFI GTR 1754 GT
Mon Jan 31, 2011 12:15 pm
:? OK, that rules out the diodes, ya already went to a Mikuni, so that rules out the stock carb issues, if it was a bad bearing you would hear it. Next step for me would be a leak down test & checkin the valve lash.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Mon Jan 31, 2011 8:17 pm
Ok, by bearing. You mean in the lower unit? Because that may be an issue. About 5 hours previous on my engine I checked my lower unit grease and it was extremely low and it wasn't due for it yet. Just throwing it out there even if it has nothing to do with it!
37EFI GTR 1754 GT
Mon Jan 31, 2011 11:44 pm
Yes, in the lower unit, but I'm willin to bet that's not the problem.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Tue Feb 01, 2011 2:38 pm
Users browsing this forum: Google [Bot] and 220 guests
