It is currently Tue Jul 01, 2025 7:00 am
Reply to topic  [ 4 posts ]
 23 mb rpm's
Post 23 mb rpm's
2009 mb 23 has bps exhaust and thats it. i played with the governer tab and got my in the water rpm's around 4200 up from 3700. i did not run for over a min a wot. is this a safe rpm for motor or do i need to be lower. if not then what is max safe rpm's. Thanks
Tue Feb 08, 2011 5:20 pm
Post Re: 23 mb rpm's
ur in a good range right there that is if ur prop aint worn out (what im sayin is that if ur propeller is newer(not to much wear) thats a good rpm cause as ur prop wears u will pick up rpm's!!!! and u will start floatin ur valves around 4500 so i think 4200 is safe!!!
Tue Feb 08, 2011 5:59 pm
thanks prop measures 12'' across. out of water rpm's are only about 50 higher than in the water.
Tue Feb 08, 2011 8:28 pm
You have a governor that protects you. 4200 in the water is fine- you have a strong motor.
Tue Feb 08, 2011 8:42 pm
Users browsing this forum: No registered users and 148 guests
