muddiejeep
Joined: Tue Jan 13, 2009 6:24 pm Posts: 761 Location: New Orleans, LA.
 Heads or cam?
what would be better in your opinion? Have the heads decked say 0.030 and go with ss valves and valve job. Or lap the valves and instal a cam? which way would I see a better improvement?
_________________ When in doubt, throttle out. 18x60 prodrive w/36 prodrive
Wed Feb 23, 2011 8:25 pm |
craig
Joined: Tue Jan 13, 2009 7:53 pm Posts: 7515 Location: Chauvin
 Re: Heads or cam?
Get both....they go hand in hand.
_________________ 1750 GatorTail Extreme/Stage 3 37 GTR HD Procrastination is a lot like masturbation. Sure it sounds great at the time but, in the end your only f--k--g yourself.
Wed Feb 23, 2011 8:28 pm |
muddiejeep
 Re: Heads or cam?
I know they would but baby steps for some of us. One at a time.
Wed Feb 23, 2011 8:36 pm |
cb5331
 Re: Heads or cam?
Do you have a case gasket leak or any other reason to tear down the motor? If not, I'd do the heads now. Add the cam when you get the funds.
Wed Feb 23, 2011 8:40 pm |
muddiejeep
 Re: Heads or cam?
tearing the motor apart isn't an issue to me. just want best bang for the buck.
Wed Feb 23, 2011 8:53 pm |
craig
 Re: Heads or cam?
dguidry
Joined: Tue Jun 29, 2010 1:20 pm Posts: 11166 Location: Cecilia, LA
 Re: Heads or cam?
I'll let you know next week what cam alone does for performance.
_________________ Formerly:1648 Homemade Cypress Crawfish Skiff GTR23 Performance Cam and Heads; 17x46 Gator Tail with 35GTR and Hoyt's cam;s Currently: 17x48 Gator Tail with XD40 EFI. “Wisdom is not just expertise. It is knowing how much of various areas of expertise you need to know in order to make the decisions that the world needs and that you want to do,” Columbia University President Lee Bollinger.
Wed Feb 23, 2011 9:02 pm |
Team Camo
Joined: Thu Oct 01, 2009 4:49 pm Posts: 8536 Location: Bridge City, TX
 Re: Heads or cam?
_________________ 1846 GTB & 35 GTR Team Gator-Tail
Killer Kallz & ANGLE PORT dealer (409) 720-8949
Wed Feb 23, 2011 9:06 pm |
deltaduckmaster
 Re: Heads or cam?
go with Heads, a long time ago we did that to my motor first a cam really didnt notice a differance did the heads and made a big differance!! i have a buddy with just heads and his motor is strong
_________________ 17x48 extreme stage 2 GTR 20X60 DUAL RIG BOWFISHING ADDITION http://www.scalesandtailsbowfishing.com
Wed Feb 23, 2011 9:09 pm |
muddiejeep
 Re: Heads or cam?
Thanks terry, thats the kind of info I was looking for.
Wed Feb 23, 2011 9:25 pm |
deltaduckmaster
 Re: Heads or cam?
Wed Feb 23, 2011 9:29 pm |
WestEndAngler
MMT Moderator
 Re: Heads or cam?
I did not deck my heads just some port & polishing etc also added a cam & a mikuni my motor is night & day. It was my plan all along to wait until motor was out of warranty before doing anything to it. Keith over @ SETX Performance did all my mods it was close, reasonably priced & plus I had a free head job that I had won from there on MMT Radio. I debated on the mikuni for a long time, I love the easy adjustment, clean look etc.
Wed Feb 23, 2011 9:45 pm |
T-Bubba
Joined: Wed Feb 18, 2009 6:43 pm Posts: 3958 Location: Centerville, La
 Re: Heads or cam?
I would think heads
When my warranty is up I plan to just do heads. From what I understand the stock valves dont seat well in the heads.
_________________ I gave up mud motors
Wed Feb 23, 2011 9:57 pm |
muddiejeep
 Re: Heads or cam?
Wed Feb 23, 2011 10:49 pm |
cb5331
 Re: Heads or cam?
Then it's not even a question on what to do first! Fix what is broken, before fixing something that isn't. That was kinda the reason for the first question. If there was a reason to tear down the motor, then go ahead and do the cam while you have it apart. If not, do the heads first. If the heads are forked up, then it's a no brainer what to do first.
Wed Feb 23, 2011 10:57 pm |
T-Bubba
 Re: Heads or cam?
my motor failed a leakdown test with 67 hrs on it after the valves were adjusted correct...
Wed Feb 23, 2011 11:22 pm |
deadbird8
 Re: Heads or cam?
Thu Feb 24, 2011 4:54 am |
MaXXis85
 Re: Heads or cam?
If you dont do it all at once, Most people will tell you heads/exhaust, cam, then carb if you want more. A cam makes things better, but you need the additional flow from the heads to compliment it well. SO with that said get you a set of heads, and cut them down a little bit for a fresh start and you will be happy.
Thu Feb 24, 2011 7:05 am |
pokey79
Joined: Mon Nov 15, 2010 4:50 pm Posts: 2282 Location: Circumcised, Louisiana
 Re: Heads or cam?
sorry to high jack ur thread but i need info on heads to give to the guy that does head work down he has never done heads on a briggs but he does all the race cars around here!!! like port ,polish, 3 angle valve job or 5 angle how much to deck etc...........?
Thu Feb 24, 2011 7:22 am |
chad454
 Re: Heads or cam?
i shaved 50 thousanths port and flowed, 3 angle vavle job, stainless vavles, vavle spring spacers, and had the vavles lighted because the guy at the head shop said that they were too heavy for the high rpms i wanted to turn... 450$ excluding the vavles which were 126$ from gator tail
_________________ 17x52 x-treme with 35-GTR Stage 2.25
Thu Feb 24, 2011 10:54 am |
dguidry
 Re: Heads or cam?
After tearing apart my drive train, crankcase and replacing my cam, removing the heads, getting them shaved, replacing the valves, all sounds like a walk in the park by comparison.
Thu Feb 24, 2011 10:59 am |
