It is currently Wed Jul 02, 2025 4:38 pm
Reply to topic  [ 9 posts ]
 gt throttle cable
Post gt throttle cable
when i went to change the throttle cable on my gator tail gtr35, i found the new one i bought (for a go devil surface drive) has a smaller end connection (to the linkages behind the air filter). the original/oem cable on my gator tail is much thicker/beefier. see the picture - go devil on left & gator tail on right. is it fine to use the new cable i bought w/ the smaller end connection? thanks
Gator Tail GTR35 on a Go Devil 16x56
Fri Feb 18, 2011 9:22 am
Post Re: gt throttle cable
I'm not sure but being that its smaller it may come out of the bracket easier. Try it out and see
Fri Feb 18, 2011 9:41 am
rather get it rt the 1st time & was gonna return the new/go devil one if it's wrong/not as good. thx
Fri Feb 18, 2011 9:43 am
Stick it in the hole and see if it comes out easily while moving it
Fri Feb 18, 2011 9:45 am
Fri Feb 18, 2011 9:46 am
Put yer face in the myrtles.
Fri Feb 18, 2011 8:15 pm
Thu Feb 24, 2011 1:40 pm
I replaced my throttle cable on my gTR23, with an oem one from gatortail. I had to shave the end of the linkage hook so it would clear the rotating throttle assembly piece.
Thu Feb 24, 2011 1:47 pm
The GD throttle cables break a lot easier, obviously because it is smaller in diameter. I have broken 2 on my GD 35 already. They like to break right after the L on the end. It will work but will be more likely to break.
Mon Feb 28, 2011 8:45 pm
Users browsing this forum: No registered users and 156 guests
