It is currently Thu Jul 03, 2025 1:29 am
Reply to topic  [ 6 posts ]
 Jet sizes on modded motors
Post Jet sizes on modded motors
Just curious what u guys recomend for main jet sizes. I have read a few things saying that once u get up to a stage 2 and 3 u should be running a 170 to 175 in the motor to keep from running it lean and floating a valve. Or does it all depend on each motor. I currently have a 165 in it but bought a 170 and 175. I havent had the motor out to really see if its running lean on a 165 Thanks
Fri Apr 08, 2011 8:18 pm
Post Re: Jet sizes on modded motors
run it wide open and pull the choke if it speeds up put a bigger jet if it slows down your good
Fri Apr 08, 2011 8:20 pm
or stays the same speed
thanks man ill give that a try.
Fri Apr 08, 2011 8:26 pm
maybe someone else can give a lil input im not a certified mechanic
Fri Apr 08, 2011 8:38 pm
Fowl...you should be fine with a 165.
Sat Apr 09, 2011 7:17 am
Users browsing this forum: Majestic-12 [Bot] and 98 guests
