It is currently Thu Jul 03, 2025 9:56 am
Reply to topic  [ 12 posts ]
 gtr 35 speed problem
Post gtr 35 speed problem
I have a question about a GTR 35 on a 1752 alweld boat. I just got it repaired because the diodes went out in it so it runs great but i used to go alot faster over open water. I was fishing yesterday with three people in the boat and a full load of gear doing 26 mph across the shallow water but went i went deep i could not get above 18 mph. Does anyone know why it would not go faster than that over open water or is there a way to fix that. it used to do alot faster.
Sun Apr 17, 2011 2:53 pm
Post Re: gtr 35 speed problem
Is your hull in great condition on the bottom?
Sun Apr 17, 2011 2:56 pm
the hull is not in that bad of shape. Its has a few scars but no bends in it .
Sun Apr 17, 2011 10:59 pm
I am gonna lean towards your prop
Mon Apr 18, 2011 7:43 am
sure your throttle cable aint slipped back some?
18x58 w/healthy GTR 35
"A good friend will bail you out of jail but a true friend will be sitting by you saying damn that was fun"
Mon Apr 18, 2011 10:32 pm
The throttle cable seems to be ok but how do i check that? My prop is a little chewed up from sand but it doesnt look that bad? with just me in the boat it will do near 30 mph. I guess the problem is in open water with a load it wont get up on plane.
Tue Apr 19, 2011 10:55 pm
What if i put some sort of cavitation plate on it would that do the trick?
Tue Apr 19, 2011 10:57 pm
MMT Moderator
GTB 1860 w/ 2019 GTR40XD-HO
Wed Apr 20, 2011 6:29 am
I have the same problems and I am running a 1752 gt extreme and I had three people in the boat with a fishing load and it would only run 18mph. The motor would only turn around 3400 rpm's and usually it runs around 3800 rpm's.
Wed Apr 20, 2011 7:09 am
MMT Moderator
Wed Apr 20, 2011 7:19 am
How do i adjust the govenor? Should i move the spring to a drifferent slot? Will that hurt the motor?
Fri Apr 22, 2011 6:13 pm
Pull the throttle cable at the screw until you have a 1/8 of play at the handle while running
Fri Apr 22, 2011 7:15 pm
Users browsing this forum: No registered users and 117 guests
