It is currently Thu Jul 03, 2025 8:36 am
Reply to topic  [ 5 posts ]
 35 hp Vangaurd Question
Post 35 hp Vangaurd Question
I have an 08 35hp Vangaurd longtail and have ben having some problems with it as of lately. It will crank right up but doesn't seem to be running as many rpm's as normal. When on the water it will run fine for a while and start choking down and will not get back up on plane it aslo blows some black smoke. I've ran sea foam through it and that hasnt helped much. Do you guys think it is an ethanol related problem or something bigger? I would have already taken it to the shop but the guy to go to just had knee surgery, thanks for any help!
Thu Apr 28, 2011 10:46 am
Post Re: 35 hp Vangaurd Question
I would say check your choke and make sure it is fully disengaging, this happened to me, choke was real loose and started closing after a little run time....might help might not
Thu Apr 28, 2011 11:30 am
Alright I'll check it out, I have had some trouble with the hook on the pull-knob coming loose so that may be it! Thanks for the response!
Thu Apr 28, 2011 12:02 pm
Thu Apr 28, 2011 12:32 pm
Could also be valve seals.......
If I can't Break it, it can't be Broke.............................
Thu Apr 28, 2011 12:34 pm
Users browsing this forum: No registered users and 102 guests
