It is currently Thu Jul 03, 2025 6:09 pm
[ 6 posts ] |
help with old 18hp briggs
landshark
I have an old 18hp gd that will not start. I have fire at both plugs and fuel to the carb. I gave it a shot of carb cleaner and it ran for a few seconds and then died. Now it will not even do that. Any suggestions would be helpful.
Mon Jun 13, 2011 11:14 am |
bobbyjober
Joined: Sun Aug 08, 2010 3:28 pm Posts: 546 Location: St. Martinville, La
 Re: help with old 18hp briggs
Sounds to me if you gave it a shot of carb cleaner through the air intake to make it run, your jets not delivering the gas. So clean the carb or rebuild it and that should work. Also make sure you got some good fresh gasoline.
_________________ 1542 FLATBOTTOM WITH 24 HONDA MUD BUDDY MINI TURNING A 12" GDSD PROP/17 FT XPRESS CENTER CONSOLE WITH 90 MARINER
Mon Jun 13, 2011 2:59 pm |
MaXXis85
Clean carb well, check flywheel/magneto gap, and check plug gap.
Mon Jun 13, 2011 3:07 pm |
pokey79
Joined: Mon Nov 15, 2010 4:50 pm Posts: 2282 Location: Circumcised, Louisiana
check to see if u have the anti backfire solenoid!!! cause it could be bad and not lettin fuel threw ur jets!!!!
Mon Jun 13, 2011 3:49 pm |
postalpaul
Joined: Sun Nov 01, 2009 6:25 pm Posts: 1935 Location: Kaufman- TEXAS
What theses men said it's a carb problem
Mon Jun 13, 2011 4:26 pm |
landshark
I greatly appreciate the help. It ran fine two days ago, so I guess I will pull the carb apart and see if cleaning resolves the problem.
Mon Jun 13, 2011 5:41 pm |
[ 6 posts ] |
Users browsing this forum: No registered users and 149 guests |
