It is currently Sat Jul 05, 2025 8:56 am
Reply to topic  [ 11 posts ]
 35 hp surface drive NEED HELP!!
Post 35 hp surface drive NEED HELP!!
Motor is bone stock and has 112 hrs on it. With one person runs great, 2 people little worse, 3 people sucks and 4 people impossible. When you give the motor gas to take off it just bogs down and doesnt want to take off. im turning between 38 and 4200 rpms with just me in the boat. Any reccomendations on what to do to this motor. Only thing i have done is put new spark plugs in it nothing else has been done.
thanks cory
Tue Jun 14, 2011 1:05 pm
Post Re: 35 hp surface drive NEED HELP!!
Hull Details ???
Prop condition ???
MM brand ???
Eat - Sleep - Hunt ! ! !
Tue Jun 14, 2011 1:16 pm
Props in really good shape not much wear.
brigs 35 hp surface drive
It has never been torn into, nothing has been updated to the motor. It is a 2008
On a mudd buddy edition excell boat
Tue Jun 14, 2011 1:21 pm
MMT Moderator
I'd say more prop or hull issues... MM brand shouldn't matter its a 35 B&S. 4 people is a lot of weight but still should be able to cruise at 22-25 MPH depending upon boat setup etc
GTB 1860 w/ 2019 GTR40XD-HO
Tue Jun 14, 2011 1:23 pm
Clean the carb & change filter if needed.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Tue Jun 14, 2011 1:29 pm
If his boat is only 14 r 15 foot long, that could b the problem. Not giving many details 4 an answer that needs a lot of detail.
U need a longer, wider boat so u can handle more load.
The problem could b that it's a GDSD wif no neutral r reverse, just kidding.
18'x54"CC Hanko/ 36PD
Tue Jun 14, 2011 5:32 pm
The motor is on a 1854 excell. It used to rn better then what it does now is what i mean. The prop is fine. Ive just heard people talk about getting valve jobs done and that helps. If its needed.
Tue Jun 14, 2011 7:25 pm
Measure your prop. Just because it looks OK don't mean it is.
If the bottom of your boat isn't all beat up and u r still turning the same Rpms, about the only other thing is your prop.
A valve job would simply improve the engine as a whole but isn't absolutely needed.
Tue Jun 14, 2011 7:48 pm
17x48 extreme stage 2 GTR
Tue Jun 14, 2011 7:52 pm
x2 on what Terry said...
get the valves checked and maybe see if your carb has any trash in it.
I gave up mud motors
Tue Jun 14, 2011 7:59 pm
With that many hours have u adjusted ur valves???
Tue Jun 14, 2011 8:00 pm
Users browsing this forum: No registered users and 143 guests
