It is currently Fri Jul 04, 2025 4:35 pm
Reply to topic  [ 15 posts ]
 Transom Angle?
Post Transom Angle?
How does transom angle play a factor in how well a surface drive performs on a boat?
What seem to be the average angle on most MM rigs; and what angle works best for the different brands?
Running an 1860 Gator Tail Extreme with a 25 Horse Merc
Tue Jul 05, 2011 9:13 pm
Post Re: Transom Angle?
I have a custom hull and my transom angle is about 17 or 18 degreez, Transom angle has a huge role in how your mud motor performs.......
Tue Jul 05, 2011 9:18 pm
This is a big factor on why the average ribbed hull does poorly with a MM cause
it's angle is setup for the average outboard....
Short answer - LT won't care about angle as much as height - balanced SD won't either
but the weighted back designs need a specific angle to work right and each has a different
"ideal angle" - which you find on their brand hull.... Best reason to buy a matched set
or use a custom builder who knows how to tweak exact height - trailing edge design - and
also angle - for your MM brand of choice ! ! !
Eat - Sleep - Hunt ! ! !
Tue Jul 05, 2011 9:26 pm
How does the different angle cause problems?
Wed Jul 06, 2011 7:02 am
Wed Jul 06, 2011 7:20 am
Wed Jul 06, 2011 7:24 am
Wed Jul 06, 2011 7:31 am
Transom height needs to be right. Trim won't fix a long shaft on a 16 r 17 r 18 inch transom.
If u want 2 get the extra speed at wot get a hydraulic jack plate.
18'x54"CC Hanko/ 36PD
Wed Jul 06, 2011 7:50 am
i wasnt referring to height. strictly just angle
Wed Jul 06, 2011 7:51 am
I do understand the whole transom height game; but was questioning on the transom angle setup.
In general shouldn't a surface drive be able to run on almost any boat that has a transom angle other than straight (outboard setup only), just by adjusting the trim?
Wed Jul 06, 2011 8:01 am
Post Transom Angle?
You need both height and angle to be right to get full performance!! Trim helps some but depending on angle will hurt you , either won't go low enough or high enough!!
17x48 extreme stage 2 GTR
Wed Jul 06, 2011 8:02 am
Wed Jul 06, 2011 8:55 am
Post Transom Angle?
All I know is my GDSD 35 and my MB 35 both like 23 degree transoms
Wed Jul 06, 2011 10:25 am
Wed Jul 06, 2011 11:00 am
Thu Jul 07, 2011 7:11 am
Users browsing this forum: Google [Bot] and 154 guests
