It is currently Fri Jul 04, 2025 4:26 pm
Reply to topic  [ 10 posts ]
 35hp gator tail touble
Post 35hp gator tail touble
the motor will do everything but start. the starter just winds and winds. my kill sitch only has one black wire hooked to it and a brown and orange wire hanging thats not hooked up...ive always run it like that but could that be the problem? any help is appreciated.
16x44 Hanko Skiff
35GTR
Fri Jul 08, 2011 3:23 pm
Post Re: 35hp gator tail touble
Do you have a tachometer? if so, does it register rpms while cranking?
If it does, then you have a fuel (or lack of) problem. If not, then your ignition system is not firing.
Fri Jul 08, 2011 3:31 pm
i dont have a tachometer...im new to the mudmotors, how could i diagnose these problems?
16x44 Hanko Skiff
35GTR
Fri Jul 08, 2011 3:59 pm
To check to see if you're firing, you can either go to the parts house & buy a spark tester, or pull a plug wire & stick a screwdriver in it while cranking it. The second option usually works better if you get someone else to hold the screwdriver. :lol:
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Fri Jul 08, 2011 4:04 pm
From your other post- did you re-wire your key switch and this is happening afterward?
viewtopic.php?f=3&t=19806
Fri Jul 08, 2011 4:32 pm
yes this is after my key switch has been re wired. i had fire in the spark plugs before the key switch incident and everything was working fine...it just seems as if the kill switch isnt hooked up but i could be wrong
16x44 Hanko Skiff
35GTR
Fri Jul 08, 2011 6:04 pm
Without a tach, its harder to pinpoint (the first check is what BoatDr posted- eliminates alot of variables). The following assumes you have fuel (check the fuel filter). Not sure on the Gatortail but I bet its similar to a MB, If clutch is engaged- the MB will not crank. 3 things will allow you to crank but not fire:
1) Kill switch not engaged grounding the coils
2) Oil Pressure solenoid tripped grounding the coils
3) Stock Carb Solenoid not engaging and blocking fuel (make sure this is connected)
If you turn the key and hear the stock carb solenoid click then its probably not #3. You can unhook the Oil Pressure solenoid and see if it fires to eliminate #2. Then use the link I sent in that other post and go look at the MB wiring diagram (which includes the full Briggs motor diagram) and re-check all your switch connections. The next thing to try would be to remove the cowling and disconnect the ground wires to the coils. See if it starts (NOTE you will have to choke it or remove the plug wires to kill it, as the switch or kill switch will not turn it off with those wires disconnected). Be careful of the fan and don't run it long without the cowling.
Fri Jul 08, 2011 6:33 pm
Eat - Sleep - Hunt ! ! !
Fri Jul 08, 2011 7:10 pm
35 GTR pushing an 18' Alumitech Custom
Fri Jul 08, 2011 9:35 pm
has to be a wiring problem, the strter just winds and winds but the motor does not fire
16x44 Hanko Skiff
35GTR
Fri Jul 08, 2011 9:39 pm
Users browsing this forum: No registered users and 148 guests
