It is currently Wed Jul 09, 2025 9:37 pm
Reply to topic  [ 3 posts ]
 Cam before heads
Post Cam before heads
Would it be ok to do a cam before heads.
23 hp gdlt pushin the 14ft NoWeld "aka" the black pearl
35 hp gdsd pushin a 16/60 go devil boat
Sun Jul 17, 2011 9:07 am
Post Re: Cam before heads
Another point is the head work will give you two things-
-Shimmed valve springs so you can run higher RPM without valve float
-Valve work helps eliminate the problem of the leaking stock vavles (which robs power)
I would suggest installing the 'bolt on' mods before going into the block. My 2 cents.
Stock valves suck:
Mon Jul 18, 2011 5:58 am
Yea I'm just gonna get both done atvthe same time
Mon Jul 18, 2011 6:41 am
Users browsing this forum: No registered users and 133 guests
