It is currently Sun Jul 06, 2025 12:38 am
Reply to topic  [ 9 posts ]
 Carb problem
Post Carb problem
I can start the motor at my house. Leave to go put boat in water travel maybe 20 min and motor won't start. When I turn it over it pops and sputters like it is flooded can anyone please help me thanks
ranger r83vs with 175 merc ........... brother breaux 18x48 with a 36 fpr pd no mods
Sat Jul 30, 2011 8:29 am
Profile YIM
Post Re: Carb problem
Are you saying after a 20 min ride on the trailer it won't start, or a 20 min boat ride it won't start? Is it running & then dies & won't start again, or after you shut it off it won't start again?
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sat Jul 30, 2011 8:40 am
Sounds like it's allergic to water.
Sat Jul 30, 2011 10:22 am
A 20 min trailer ride. I can get it started it takes about 5 mins of spinning it over and u can smell the gas.after I get it running it starts fine
Sat Jul 30, 2011 11:34 am
Profile YIM
When it is running what rpm's does it idle at?
Sat Jul 30, 2011 11:58 am
Kinda sounds like ur carb float is stickin open or partially choked
Sat Jul 30, 2011 12:35 pm
Around 900 Rpms
Sat Jul 30, 2011 4:58 pm
Profile YIM
Sounds like a float issue to me where bouncing on the trailer is spilling over into the intake then the combustion chamber. You may also have trash in the needle but that would likely cause it to run rich on the water. Suggest you pull the fuel bowl and check the float out.
Russ
Sat Jul 30, 2011 6:43 pm
Sun Jul 31, 2011 9:02 am
Users browsing this forum: No registered users and 119 guests
