It is currently Thu Sep 18, 2025 6:06 am
Reply to topic  [ 9 posts ]
 Sea Foam
Post Sea Foam
Use It ! that is all.
Sat May 23, 2009 7:59 pm
Post Re: Sea Foam
Not to jack your thread but, anyone try to run a little Yamaha Ringfree or Mercury Quickleen to get out any carbon build-up in the heads? They are safe to run in 4-strokes, a oil change is recommended after the initial shock treatment.
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Sat May 23, 2009 8:04 pm
Post Re: Sea Foam
Crisis defines character
Sat May 23, 2009 9:10 pm
Post Re: Sea Foam
ditto
Sat May 23, 2009 9:34 pm
Post Re: Sea Foam
Sat May 23, 2009 11:07 pm
Post Re: Sea Foam
Sun May 24, 2009 9:39 am
Post Re: Sea Foam
well, that stuff is expensive so I only use it about every 3rd or 4th tank. Keeps everything clean from what I can tell.
If you store your boat out in the sun you have a better chance of getting some condensation in the fuel. Keep that in mind...
Sun May 24, 2009 12:08 pm
Post Re: Sea Foam
18x48 Charles Leonard / 36PD
Sun May 24, 2009 7:13 pm
Post Re: Sea Foam
I use... maybe too much. Is there such a thing as too much Sea Foam? The mo the betta i say....
Josh
"Grace calls us to change and then gives us the power to pull it off!"
Max Lucado
Wed May 27, 2009 2:59 pm
