It is currently Fri Jul 11, 2025 9:44 am
Reply to topic  [ 14 posts ]
 Bogging Bad!
Post Bogging Bad!
Ok i installed the Mikuni BPS kit on my 23hp gtr with the MM exhaust and test ran it. At idle it was high so i adjusted it to around 1100rpm/s OOW. In water idle in gear drops to 650 and don't die. Problem i had was from Idle to 2300 rpms in the water it boggs bad and i have to feather the throttle so it dont fall on its face. But once on plain up to 3/4 throttle it screams all the way to 3750 rpm's then from 3/4 to full throttle it loses about 150 rpm's. whats sounds like the problem? i'm lost on this! Wrong jet, to big? heads cant flow enough to keep up with gas coming in? HHHHEEELLLLPPPPP!
Mon Aug 29, 2011 8:24 am
Post Re: Bogging Bad!
sounds like its dumping to much fuel at once. try the jets.
Mon Aug 29, 2011 8:40 am
Howdy stranger! :lol: go smaller i'm guessing?
Mon Aug 29, 2011 8:42 am
yes sir!
Mon Aug 29, 2011 8:47 am
how you know so much about these Engines? :lol:
Gonna call micha at MB and ask him what size would be preferable.
Mon Aug 29, 2011 8:55 am
Drop your high speed jet down 1-2 sizes.
Mon Aug 29, 2011 8:56 am
where can i get these so said jets?
Oh and at 3/4 throttle its running 3800 rpm's tilted as high as it will go. also if i tilt it just a bump down it speeds up ut drops to around 3720. also my boat it beat to piss on the bottom! :lol:
Mon Aug 29, 2011 9:01 am
Post Bogging Bad!
Where are you located?
Mon Aug 29, 2011 9:30 am
SETX
Ok called Micha at MB. he said to run it without the K/N filter to see if it helps. he said the 23hp does that cause the carb for its a bite to much for it. that without the filter it should help. he also said to play with the air/fuel mixture screw, to back it out some. whats yall thoughts on this? i need to sun some kinda filter so trash dont get in it.
Mon Aug 29, 2011 10:30 am
Mon Aug 29, 2011 11:01 am
so no carb should fix it? i would prefer to run a carb or something to keep water, and dust out of it while running and or trailering. its got a 180 jet in it right now.
Mon Aug 29, 2011 11:29 am
Mon Aug 29, 2011 3:06 pm
Yea, I pm'ed him. Thanks for that. I don't want to gave to play the throttle during hunting season. Ill check my plugs maybe go with a hotter plug. Also might look into dropping a jet size.
Mon Aug 29, 2011 5:14 pm
Should not have a carb bigger than a 33mm on that motor.
Mon Aug 29, 2011 9:04 pm
Users browsing this forum: No registered users and 131 guests
