It is currently Wed Jul 09, 2025 7:05 am
Reply to topic  [ 23 posts ]
 Gt23 SLOW why?
Post Gt23 SLOW why?
I have a gt 23 on a 1652 flat bottom John I cannot get the boat over 13 mph with just one person in it and was just wondering if anyone had any tips or thoughts why it is the motor only has 19 hours I don't think it should b this slow
Thu Sep 01, 2011 8:18 pm
Post Re: Gt23 SLOW why?
i had a 1648 flat bottom john with a gtr35 and all i could get was 22 it is the boat they dont run worth a crap and u are underpowerd
17x 54 with a 35GTR with Calens stage 1
Thu Sep 01, 2011 8:25 pm
3 possible issues:
1) Boat is tall transom & motor is short transom (strong possibility)
2) Boat is just too big & heavy for the motor (doubt it)
3) Bottom of boat is hooked or beat to shit (stronger possibility)
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Thu Sep 01, 2011 8:40 pm
don't your weight distributed even in your boat. and sounds like your kinda underpowered to me that boat is pretty wide
Gave up hunting ducks and started underwater basket weaving!
Thu Sep 01, 2011 8:50 pm
1648 welded with 31hp sport mud buddy with single crossover pipe and new black death carb and big blade prop 2 guys 23-24 and 3 guys 15-17. o yah i have pods on my boat and they do help. i hope this info helps
Thu Sep 01, 2011 9:56 pm
23 MB mini w/ IM heads, BPS rockers/rods and gutted exhaust on a rivited 1648 crestliner.
Thu Sep 01, 2011 10:10 pm
takeen1268 do you have it trimmed where it runs the best speed. also on a small boat like 14-16 ft the weight need to be disturbed like gas tank and battery in the front also pods help. heres my setup stuck on hard clay http://www.youtube.com/watch?v=4hp_AZbnVEE
Thu Sep 01, 2011 10:12 pm
The guy at gatortail Hoyt said that motor should push my boat at least 18-23 with just one person he thinks it's a prop but the motor only has 19 hrs on it I can't believe it would wear that fast I do have my tank up front and the boat does plane out it's just slow I know there not speed demons but 13 mph that's crazy the boat also has pods does a true flat gotten really make that big of a dif even if u r not always running in the shallows
Fri Sep 02, 2011 1:32 pm
Post Gt23 SLOW why?
What are your rpm 's
17x48 extreme stage 2 GTR
Fri Sep 02, 2011 1:39 pm
I have a 23wonderful and its on a 1648 and it ran 23over stock with me in it and gas tanks up front. Bottom of my boats beat to piss too. I have 18.4 hours on mine also. Now it wont start! Garbs got trash I guess cause I got no gas in the bowl but have it pumping at the electric pump fine.
Fri Sep 02, 2011 2:07 pm
If the prop was run in sand it can wear down fast
Fri Sep 02, 2011 2:14 pm
how were the pods installed? are they flat with the boat or do they have a slight up turn toward the tail? if flat, they can be a real speed killer.
Fri Sep 02, 2011 3:29 pm
Pods have a 3/4 rise my rpms are at 3750 the motor was on a 1542 war eagle and it was a dog then to I just would like to know about the prop before I waste the money on one it still measures 11 inches across
Fri Sep 02, 2011 4:15 pm
Post Gt23 SLOW why?
Fri Sep 02, 2011 4:17 pm
If the cup is worn down on the prop, which doesn't take long to do sometimes, it'll still turn the rpm's, but won't push nearly like it should. On the other hand, this is the second boat you've had the motor on & it didn't perform on the other boat either, I'd suggest a leak down test just to make sure.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Fri Sep 02, 2011 4:19 pm
What exactly is a leak down test this is my first mm
Fri Sep 02, 2011 4:23 pm
is the motor timmed for the best you did say your new to mm
Fri Sep 02, 2011 10:53 pm
trimmed for the best speed sorry for the miss mistype
Fri Sep 02, 2011 10:56 pm
Where are you located? Maybe one of us are close to you and can take a look.
Sat Sep 03, 2011 5:54 am
There are a few Go Devil Prostaffs that can helps out
Sat Sep 03, 2011 8:00 am
I have a 1748 with a 23 GTR. I run 23 in deep water. At 3400 RPMs. And the prop question, about month ago I call talked to Hoyt about the prop and he said that he thinks the 23 hp prop has to much pitch in it. He is working on a new prop. That being said, I still don't think it's the prop. You need to take to someone who can look at the motor are you will send alot of money and time chasing this problem.
Sat Sep 03, 2011 5:42 pm
If the cup is worn off his prop, it won't "bite" like it should. This will result in more prop slip, making him slower at the same or higher rpm. While his problem very well could be something else, don't rule out the prop as a very strong possibility.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sat Sep 03, 2011 7:31 pm
I live in northern Illinois and would like to see someone with the knowledge to help but seeing as I am the only mm I have seen all summer it might b hard I just don't really wanna buy a prop just to try it but I guess if that's what I gotta do o well but I e mailed Hoyt a bunch of pics just waiting for a reply
Sun Sep 04, 2011 2:33 pm
Users browsing this forum: No registered users and 70 guests
