med
Joined: Wed Jan 14, 2009 8:25 am Posts: 6432 Location: the dark side of the moon
 Loose key
My key is really loose in the ignition except when its on. Is there any way to fix it so the key won't fall out when the engine is off?
_________________ 1850 & 36pd
Sat Sep 10, 2011 12:00 am |
autogateman
Joined: Thu Sep 16, 2010 10:32 pm Posts: 4036 Location: Gonzales La
 Loose key
Go to auto zone and buy a new switch for about fifteen bucks. Problem solved.
Sat Sep 10, 2011 5:35 am |
cb5331
 Re: Loose key
^yep
Sat Sep 10, 2011 9:15 am |
med
 Re: Loose key
cool. Thanks
Sat Sep 10, 2011 9:45 am |
earl33
Joined: Wed Sep 16, 2009 3:47 pm Posts: 2261 Location: West Tennessee
 Loose key
Or loc tight the key in.
_________________ If the Steel aint Flying the Birds aint Dying.... Uncle J 1948 holding a LT Uncle J 1848 w/?
Sat Sep 10, 2011 9:53 am |
med
 Re: Loose key
Ill probably just live with it a while instead of having to put a new ignition in and run wire.
Sat Sep 10, 2011 10:29 am |
deadbird8
 Re: Loose key
Tie a length of twine to the key and to the lift eye so if it falls out, it still there.
Sat Sep 10, 2011 1:00 pm |
autogateman
 Loose key
Sat Sep 10, 2011 1:13 pm |
Beadlejuicejr
Joined: Tue Nov 02, 2010 7:11 pm Posts: 1435 Location: Bayou vista, Louisiana
 Re: Loose key
Drill a lil hole in the plastic close to it and tie it up
_________________ stage 3 GTR screaming behind the 1848 Garrett Pearce special. GET YOU SOME!
Sat Sep 10, 2011 2:26 pm |
pochunter
 Loose key
Sat Sep 10, 2011 3:36 pm |
earl33
 Loose key
Loc tight is a lot easier. One drop and your done. If your scared someone will drive off with your boat because the key is glued in the switch then what will they do with your boat when the key is tied by some string to the motor? Just wondering??
Sat Sep 10, 2011 8:52 pm |
