It is currently Thu Jul 10, 2025 3:34 pm
[ 7 posts ] |
Minkuni with < 45 hrs started sputtering/loss of power
Joe Guide
Joined: Mon Nov 02, 2009 7:58 pm Posts: 159 Location: Coastal North Carolina
I appreciate some helpful comments or suggestions.
My minkuni runs normal RPMs -out of water, but underway started "popping" and struggling to power my MB this afternoon. This is not normal, and I had previously ran all the fuel out prior after running it last friday and it ran super.
Today it appears that the minkuni seems struggling for fuel; however there lies the issue - the fuel line is primed and fuel is there. Also there doesn't seems to be any leaking of fuel from the overflow tube.
Could the popping be there is a "air leak' issue and not a fuel issue? I do not know much about these minkuni's but it has been quite reliable for many months of running short distances out in the saltmarsh.
I was going to pull it off tomorrow and clean it, and inspect the jet.
Is there anything else you fellows with minkuni's might also suggest?
Thanks..... Joe Guide
_________________ Check out "Joe Guide hunting videos" on YOUTUBE...
Mon Sep 05, 2011 6:16 pm |
deadbird8
 Re: Minkuni with < 45 hrs started sputtering/loss of power
Mon Sep 05, 2011 6:43 pm |
Team Camo
Joined: Thu Oct 01, 2009 4:49 pm Posts: 8536 Location: Bridge City, TX
Could possibly be an intake leak, bad diodes, a bad coil, bad oil pressure sensor, or a few other possibilities.
To check for intake leak, take some WD40 or brake parts cleaner & spray around all the joints on the intake system while the engine's running. If it idles up or down suddenly, then you have an intake leak right where you're spraying.
To check the oil pressure sensor, simply unplug it & run the motor as normal & see if the problem continues. It's located right by the oil filter.
To test the diodes, you have to unplug them from the coils & run the motor under a load. If the problem continues, then the diodes are ok. WARNING!!!! With the diodes unplugged, you won't be able to shut off the engine with the key or kill switch. Just remove the air filter & smother the air intake with your hand & the engine will die.
Again, could just be some build-up in the carb from fuel line break-down & carb needs a cleaning. Good luck & happy hunting.
_________________ 1846 GTB & 35 GTR Team Gator-Tail
Killer Kallz & ANGLE PORT dealer (409) 720-8949
Mon Sep 05, 2011 6:48 pm |
Joe Guide
Thank you for the quick reply and comments and will certainly look into those issue tomorrow.
Mon Sep 05, 2011 8:22 pm |
autogateman
Joined: Thu Sep 16, 2010 10:32 pm Posts: 4036 Location: Gonzales La
sounds like an intake leak to me also.
Mon Sep 05, 2011 8:24 pm |
Joe Guide
Thanks for all those who commented...but it was a bad "coil"/magneto on the right side.
It was cutting out, popping, with blacked plug on that right side, and had a severe loss of power with half of normal RPM under a load. Out of water it was pulling proper RPMs
Mr. Warren Coco got me covered with a new Coil under warranty, and Tom and Dan over at "Atlantic Marine Power Equipment" (a Briggs & S shop) in Hampstead, NC that is the only shop that works on Mud Motors in coastal North Carolina. They got me fixed and back on the water.
Fri Sep 09, 2011 8:52 pm |
deadbird8
Glad you got it figured out.
Sun Sep 11, 2011 5:56 am |
[ 7 posts ] |
Users browsing this forum: No registered users and 123 guests |
