It is currently Thu Jul 10, 2025 6:15 am
Reply to topic  [ 32 posts ]
 Ribbed vs. Smooth bottom
Post Ribbed vs. Smooth bottom
How big of a difference does a smooth bottom make than a ribbed bottom boat in the lilies and mud?
16x44 Hanko Skiff
35GTR
Tue Sep 27, 2011 2:16 pm
Post Re: Ribbed vs. Smooth bottom
Look, first of all your posts are pretty much in the WRONG forum, but to answer your post smooth bottoms have less drag.
Bayou Surface Drive
337-351-0362
Tarkington, TX 77327
Tue Sep 27, 2011 2:24 pm
Running an 1860 Gator Tail Extreme with a 25 Horse Merc
Tue Sep 27, 2011 3:28 pm
Ive witnessed both first hand, it makes all the difference but its a sliding little bitch in shallow water.
Tue Sep 27, 2011 3:30 pm
the difference in going with the slick and sticking with a ribbed
16x56 epidemic slick bottom with mini 4000
Tue Sep 27, 2011 3:41 pm
Alot and I will likley never go back to a ribbed boat for a mud motor.
Think about this. You have a 48" wide bottom with both style boats.
The smooth bottom is 48" wide
The ribbbed boat is 48" wide but has 5 ribs, 1 inch down, 1" wide, 1 inch back up on each rib. That is 2 more inches of drag per rib or 10" total. Now you have a 58" wide bottom surface with still only a 48" wide boat. More drag and 5 ribs to catch and hold on to what ever you contact. IMO slick is the way to go...Duckdon
Tue Sep 27, 2011 3:47 pm
My skiff is 40" wide 19' long and has 3, 1-1/2" corrigations (ribs or runners) on the bottom. It doesnt slide one bit, It also goes where any of yall boats will go. Ive been on the mud runs and compared the two and went more places than most. I dont find they hurt one bit in the mud. If your motor cant handle the little xtra drag those little things put on your boat then ya got problems. I actually prefer mine over a smooth bottom. Only downfall I had was when I would hang up on cypress knees while crawfishing, I couldnt slide the boat sideways off of them. I had to just go forward or back off of them. Other than that, I can run wide open down the skinniest, curviest bayous and not slide at all. I like it. Been running this boat for almost 2 years and will probably have runners on my next boat too. They also help stiffen up the bottom .
Tue Sep 27, 2011 4:35 pm
If you have anything on the bottom it will not go where a completely slick bottom will ;) Just won't!!
Tue Sep 27, 2011 4:39 pm
Smooth bottom would be the smart mans choice for a
mud motor.
35gtr Stage 1 On 19'3"x46" Mad man Hull going Places far and beyond
Tue Sep 27, 2011 4:45 pm
tenpoint i find this interesting. i take it its one u built?
Tue Sep 27, 2011 4:55 pm
Tue Sep 27, 2011 5:01 pm
Tue Sep 27, 2011 5:03 pm
Tue Sep 27, 2011 5:04 pm
no interesting in what u know. always heard smooth is better.
Tue Sep 27, 2011 5:16 pm
Tue Sep 27, 2011 5:25 pm
No doubt the ribs track better.
I have a ribbed boat and it doesn't hold me back in grass.
The only thing is on stumps and trying to slide over beaver dams and stuff it will hang.
Tue Sep 27, 2011 7:18 pm
in the nastiest of mud flats a ribbed bottom will not turn as good as a flat (smooth bottom)!!
Tue Sep 27, 2011 7:24 pm
I've run smooth and ribbed bottoms, and I have to agree with Tenpoint for the most part. 99% of the time a ribbed will go where a smooth will. The one real advantage of a smooth bottom is it is easier turn around if you are pushing it out of the mud. The ribs will grab more in the mud. I guess you can go through a little more chit with a smooth bottom, but once you get past the phase of seeing what you CAN run through, and start using the boat to run through what you NEED to, the ribbed bottom will be just fine. A corrugated bottom will be much stronger and rigid than a smooth bottom. Not to mention better manuverabilty. All that said, I still prefer a smooth bottom for a mud boat, but my next skiff will have plenty of runners.
1854 Sportsman's Fab
2046 Uncle-J Skiff
35 GTR
Tue Sep 27, 2011 7:37 pm
Slick bottom with round or tapered chines.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Tue Sep 27, 2011 7:38 pm
It's comon since that a smooth will hang on less than a ribbed. Although, there's alot of variables that go into it as well, some ribbed boats, depending on situations will go just as many places as slicks. How? No idea. I'd been on both and can say the slick would definitely run circles around the ribbed any day. But, I've seen ribbed boats go places slicks do to. I think it may depend on how wid they are and how much they weigh. Check out the vids of chops. Dude runs in some pretty nasty stuff, on an old ass rough looking ribbed boat, running all the places the slicks are. All in all, slicks will do better in mud and veggies. As to how much better depends all on the situation as I stated above.
Tue Sep 27, 2011 7:46 pm
Brasso, you can't use that as a comparison. That is an old light ass Alweld hull that had a whole lot more hp than it needed.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Tue Sep 27, 2011 7:51 pm
Oh I know, that's why I said "it depends on the situation"
Tue Sep 27, 2011 7:53 pm
I would be running mostly grass and lilies and occasionally some mud
16x44 Hanko Skiff
35GTR
Tue Sep 27, 2011 8:33 pm
slick bottom only good with round or taper chine imo.
had a ribbed bottom boat for years and always wanted slick bottom.
now have a slick bottom and want tenpoint to weld a coupla runners on the bottom.
i guess if all you did was PLAY on mudflats with the boat,youd want it slick and lite as possible.
myself,i like the turning ability the runners give you.
plus it makes the bottom that much stronger.
Tue Sep 27, 2011 8:57 pm
GatorTail Xtreme hull,Slick bottom and will turn :D
Wed Sep 28, 2011 5:30 am
My buddy used to have a Mod Vee with a crimped bottom... Had a 40 Evinrude on the back and That mofo SLID.. One time i was taking it back from the Camp. I had it sliding in the intracostal getting back to the Franklin.. Crimped bots still slide when You get most of the raggedy hull out of the water :lol:
Bayou Surface Drive
337-351-0362
Wed Sep 28, 2011 6:19 am
A crimped 1/8" bottom will b much more strong and rigid than a 1/8" flat bottom. I'll never own a slick bottom, can't c where it could be that much better.
18'x54"CC Hanko/ 36PD
Wed Sep 28, 2011 6:58 pm
Get stuck were theres no water and hard ground you'd wish it was slick bottom and not have runners. Been there done that hell with runners unless it on a boat that wount see these kinda conditions
stage 3 GTR screaming behind the 1848 Garrett Pearce special. GET YOU SOME!
Wed Sep 28, 2011 8:11 pm
Wed Sep 28, 2011 8:24 pm
Wed Sep 28, 2011 8:32 pm
That hard ground sneaks up on you... :lol:
Wed Sep 28, 2011 8:35 pm
Wed Sep 28, 2011 11:17 pm
Users browsing this forum: Google [Bot] and 89 guests
