RVOutfitters
Joined: Wed Oct 19, 2011 10:16 pm Posts: 8 Location: Northern California
 New to the Forum - War Eagle/Pro Drive Question
Hey guys, new to the mud boat scene but jumped right in. I have a 16x48 War Eagle with a 32hp ProDrive. Seems like it is is a little heavy in the rear - do the flotation pods really help out?
Wed Oct 19, 2011 10:42 pm |
Woodiebuster
 Re: New to the Forum - War Eagle/Pro Drive Question
No, save yourself money and misery and get a 18x48 mud hull.
Wed Oct 19, 2011 10:53 pm |
med
Joined: Wed Jan 14, 2009 8:25 am Posts: 6432 Location: the dark side of the moon
X2....or just a mud hull. Don't have to be that exact size
_________________ 1850 & 36pd
Thu Oct 20, 2011 2:01 am |
cb5331
Been there, done that. Would not recommend it. Sell it while it's still in good shape and get a hull built for the motor.
Thu Oct 20, 2011 7:10 am |
petrel
Joined: Mon Jan 11, 2010 9:51 am Posts: 770 Location: NVA
Another vote for a mud hull. If you want to keep your War Eagle, you could move the battery and fuel tank to the bow to see if it helps the weight distribution.
_________________ Phowler 2066 w/ E5 37 ProDrive w/ Illowa Marine Heads MoMarsh Fatboy/2 Honda
Thu Oct 20, 2011 7:41 am |
h2ofowlhunter
Joined: Sun Oct 09, 2011 8:57 am Posts: 72 Location: Buffalo, Tx
I just bought some pods from Boyd welding in Florida. I have an Xpress 16x50. Made huge difference in deep water take off and now the rear of the boat drafts about 6" less than before. Cost a lot less than new boat.
_________________ Gator Trax 1850HD/ MB 6000
Thu Oct 20, 2011 8:36 am |
cb5331
Depends on what he can get for his boat and how much he can pick up a new or even used hull for. War eagles are not super cheap and they are a good match for an outboard, he may be able to make the switch without spending much money, maybe less than it costs to install pods. That hull will never perform properly with a pd on it no matter how much money you spend on it anyway. Now is the time to bite the bullet. Better to get what you can now, than spend more money on it, still not be happy, and then have to settle for what you can get after you've started hacking it up. JMO. Like I said, we've been down this road before. A hull designed for the motor will outperform that war eagle in pretty much every scenario.
Thu Oct 20, 2011 8:41 am |
sedlmayrje1723
I have attempted that battle already even with a 18 fott boat. Just listen to these guys and get a mud motor hull. Don't even mess around. Waste of money as far as I am concerned.
Thu Oct 20, 2011 9:42 am |
russellm454
Thu Oct 20, 2011 3:22 pm |
dpd
Joined: Thu May 07, 2009 10:25 am Posts: 714 Location: Thibodaux, LA
Pods may help, but check with others that went with pods on a Prodrive. I am almost certain pods will not allow u to ratchet the reverse around. The pods will get in the way . IMO that's alot to give up for what u hope to gain.
_________________ 16 x 48 Blanchard Bateau / 40 PD FPR Eat,Sleep, Fish, Hunt. Repeat.
Fri Oct 21, 2011 8:25 pm |
da go get'er
Joined: Wed Oct 27, 2010 8:30 am Posts: 3406 Location: Prairieville
_________________ 17*38 Klibert 23GDLT I toast to staying positive and testing negative!
Fri Oct 21, 2011 8:32 pm |
