It is currently Thu Jul 10, 2025 2:58 pm
Reply to topic  [ 11 posts ]
 GTR dies out
Post GTR dies out
i have a 35 hp gtr went out today cranked right up. I was at full throttle and it died out. The inline fuel filter was full to the top. It would only crank with the choke pulled out. I got it cracked up and it died out 2 more times. The last time i got it cranked it ran fine but i fuel filter stayed full up. I have no clues what is causing this.
Sat Oct 22, 2011 8:35 pm
Post Re: GTR dies out
Sea foam/carb cleaner is your friend, look real hard at your carb
Sat Oct 22, 2011 9:23 pm
Was the air vent on your gas tank open?
35 GTR / 17x54 Cajun Performance Custom
Mon Oct 24, 2011 8:42 am
Post GTR dies out
Yes the tank was open.
Mon Oct 24, 2011 9:39 am
MMT Moderator
"B&S" dies out... not a Gator-Tail issue.
GTB 1860 w/ 2019 GTR40XD-HO
Mon Oct 24, 2011 10:59 am
Coe, does Giga really make you that paranoid? I've seen you do that several time's now.
Mon Oct 24, 2011 11:17 am
1854 Brother pulling a 36 PD
viewtopic.php?f=5&t=12825
Mon Oct 24, 2011 12:00 pm
MMT Moderator
Tue Oct 25, 2011 6:38 am
Will the engine stay running if you "un-choke" it?
Tue Oct 25, 2011 6:42 am
Next time it happens - take your shoes off and touch bare metal
on the motor - if it shocks the crap outta you - you have a plug wire
arcing to the frame somewhere....
Was with someone - running strong - when motor cut out hard and
acted a bit like your describing - would start then suddenly die out
since his feet were wet and his throttle was metal aftermarket - he
would get lit up when it happened and curse like he had touretts....
Lil tape and relocation of plug wires fixed it up....
It's a 4 stroke thing.... LOL....
Eat - Sleep - Hunt ! ! !
Tue Oct 25, 2011 7:17 am
Post GTR dies out
It would only start with the choke on. then i would push the choke in and play with the throttle then it would run a while and die out. It has not done this again. I think it was bad gas
Wed Oct 26, 2011 7:33 am
Users browsing this forum: No registered users and 89 guests
