Jamie B.
 How Long Do Yall Think
A modded motor with stock pistons and stock rods will last @ 4980 rpms? Went run it yesterday for a little while opened her up and this was the results, and No Im not blowing out.
Thanks Jamie B
Tue Oct 25, 2011 7:18 am |
deltaduckmaster
No matter what you got in it they Will not last at those rpm's !!
_________________ 17x48 extreme stage 2 GTR 20X60 DUAL RIG BOWFISHING ADDITION http://www.scalesandtailsbowfishing.com
Tue Oct 25, 2011 7:24 am |
Jamie B.
 Re: How Long Do Yall Think
Yea I know, and the motor is pinned on the bottom hole. I might try swapping some pulleys around any advise on what size to start with. I dont plan on running it hard that often when i seen that, wish i would have had a GPS with me .
Thanks Jamie B
Tue Oct 25, 2011 7:34 am |
craig
Trim down. If you're spinning that high your entire prop is out of the water.
Tue Oct 25, 2011 8:18 am |
Jamie B.
Tue Oct 25, 2011 8:25 am |
pooldoo73
Joined: Tue Jan 25, 2011 5:47 pm Posts: 886 Location: Plaquemine
If your prop is a little worn it is not new. U can't change pulleys on a prodrive anyway.
_________________ 18'x54"CC Hanko/ 36PD
Tue Oct 25, 2011 9:56 am |
hunt682
Joined: Tue Jan 27, 2009 9:43 am Posts: 1127 Location: Camilla, Georgia
Tue Oct 25, 2011 10:05 am |
Jamie B.
Tue Oct 25, 2011 10:14 am |
Duckdon
Joined: Sat Apr 24, 2010 3:32 pm Posts: 407 Location: Chugiak, Alaska
Til it goes "Clunk"
Tue Oct 25, 2011 12:31 pm |
JIMMY W
Joined: Tue Jan 13, 2009 8:02 pm Posts: 4534 Location: South Louisiana
Won't last long  If you want it to last,Leave it stock!
_________________ 17/54 GT EXTREME Center Console, Huntdeck w/ GTR 35
Tue Oct 25, 2011 12:44 pm |
Team Camo
Joined: Thu Oct 01, 2009 4:49 pm Posts: 8536 Location: Bridge City, TX
Better gear it & pitch it, before ya blow it!!!!!
_________________ 1846 GTB & 35 GTR Team Gator-Tail
Killer Kallz & ANGLE PORT dealer (409) 720-8949
Tue Oct 25, 2011 12:48 pm |
MaXXis85
Tue Oct 25, 2011 12:53 pm |
deltaduckmaster
Tue Oct 25, 2011 1:01 pm |
Team Camo
Tue Oct 25, 2011 1:03 pm |
MaXXis85
Tue Oct 25, 2011 1:06 pm |
deltaduckmaster
Taking it easy with out a rev that is impossible
Tue Oct 25, 2011 1:12 pm |
MaXXis85
Tue Oct 25, 2011 1:13 pm |
Jamie B.
Thanks for yalls opinions, the reason this was posted was to get different opinions on what different people would have to say, this motor was the first of what we wanted to try different with the head work, this motor suprised the hell out of me on its first run and seems it is getting stronger every time we run it. This motor was rebuilt due to having 39% leakage on a leakdown test performed at 964 hrs with mods on motor turning 4700 to 4800 rpms. We are still tinkering with different recipes on the head work but this seems to be the strongest most consevative we have came up with as of yet. All i can say is wait till the 31 block we are working on is finished with the mahine work and rebuild complete, it will be and animal!
Thanks for the opinions, keep them rolling OH and there will be no taking it easy with this motor!
Tue Oct 25, 2011 1:28 pm |
MaXXis85
Just remmeber HOT motors only last a little while. John force's Top fuel funny car prolly gets rebuilt after each run. Good luck with your build man!
Tue Oct 25, 2011 1:33 pm |
Jamie B.
Yes sir you are correct, they dont last long being dogged out every time you put it in the water, I think with the current setup I (should) be able to run it at about 46 to 4700 pretty long, not saying i will get another 1000 hrs out of this set up but it will be fun to lay into it every once in a while.
Tue Oct 25, 2011 1:37 pm |
dog walker
Joined: Tue Jan 13, 2009 6:08 pm Posts: 5282 Location: Meraux,La.
my last one crapped out and never ran over 4400,ever.
Tue Oct 25, 2011 1:44 pm |
JIMMY W
Tue Oct 25, 2011 3:20 pm |
MaXXis85
Tue Oct 25, 2011 3:22 pm |
da go get'er
Joined: Wed Oct 27, 2010 8:30 am Posts: 3406 Location: Prairieville
_________________ 17*38 Klibert 23GDLT I toast to staying positive and testing negative!
Tue Oct 25, 2011 3:54 pm |
Jamie B.
if it happens tommorow then it was fun. I just got back from running it today with the 12x11 wheel it dropped RPMs down to 4760, still dont know speed yet due to only GPS I have is a stationary HDS7 mounted in dual rig. Seemed a little sluggish out the hole with 12x11, but its seems to really flatten out the boat on top end, so i need to get a gps on both props to give any sure speeds on different pitch props.
Tue Oct 25, 2011 4:20 pm |
Jamie B.
Whatever you do it has been done before  Maybe so, maybe not
Tue Oct 25, 2011 4:25 pm |
deadbird8
If you have the option- play with gears and props. A higher gear ratio with more aggressive prop is the best combo I have found.
I was always told stock rods ~4600 is about where you want to stay below. Guess your 900 hours disputs that.
Tue Oct 25, 2011 7:57 pm |
Team Camo
Tue Oct 25, 2011 8:29 pm |
take'emgator
Joined: Mon Oct 19, 2009 6:38 pm Posts: 10201 Location: SETX
Tue Oct 25, 2011 8:34 pm |
Jamie B.
Which by the way this GPS he is referring too beached us at 0530 in the morning and we spent 45min. trying to unbeach it, did i mention that a dual GTR rig is heavy as fork[/quote] No this is a brand new one to Play with
Wed Oct 26, 2011 6:49 am |
take'emgator
I wonder if thid one shows downed trees in the middle of the Bayou, tranaus, whatever ya'll call it, since that is the reason we ended up on the bank in the first place, that co9uld have been a bad morning for 3 of us for sure!
Wed Oct 26, 2011 11:05 am |
Jamie B.
Yep, that had the potential to take a turn for the worse real quick. I figured hit it or beach it, so I picked beach it.
Wed Oct 26, 2011 12:28 pm |
