It is currently Thu Apr 09, 2026 11:46 pm
Reply to topic  [ 6 posts ]
 smaller godevil motor swaps?
Post smaller godevil motor swaps?
what is the hp limit for a bolt on application for a 6hp go devil motor?
if i took a 5-6 hp godevil longtail, how large of a motor can i swap out on the frame? thanks
Wed Jun 17, 2009 3:53 pm
MMT Moderator
Post Re: smaller godevil motor swaps?
better call GD for that
duck wacker
Wed Jun 17, 2009 6:02 pm
Ideas not coupled with action
never become bigger than the
brain cells they occupied.
Owner
Wed Jun 17, 2009 8:45 pm
When I used to build my own if you had a 5 8-) 8-) hp briggs you can put a 10 tecumshi in its place they hadd the same bolt pattern and shaft height but the shaft was 1" instead of 3/4" but not sure bout what you have, you can also go to nortern tool and look up the engine specs where they will give you heights and stuff.
There is no replacement for displacement!!!!
Wed Jun 17, 2009 8:59 pm
i spoke with GD they said only up to a 6.5 on this frame. not sure if thats said for liability or function. my jonboats say 25 hp outboard but i run 35 on them. guess ill have to look around take some measurments
Thu Jun 18, 2009 4:42 pm
MMT Moderator
liabillty is a lot of things from mm mfgs Im sure
duck wacker
Thu Jun 18, 2009 8:39 pm
