hunterg
Joined: Tue Sep 29, 2009 10:21 pm Posts: 188 Location: SETX
 PD not reaching full RPM's
Last week on the way out from our lease my motor just randomly started bogging down real hard. it wouldnt let us get on plane and was constantly backfiring. it finally started running better and gave me enough speed to get on plane and get back to the ramp but ever since then it wont run higher than 3600 rpm's.
Any idea's?
Sat Dec 24, 2011 9:55 pm |
T-Bubba
Joined: Wed Feb 18, 2009 6:43 pm Posts: 3958 Location: Centerville, La
 Re: PD not reaching full RPM's
valves or trash in the highspeed jet
_________________ I gave up mud motors
Sat Dec 24, 2011 10:44 pm |
hunterg
any particular way to clean those out?
Sat Dec 24, 2011 11:05 pm |
T-Bubba
You would have to take the carb apart or check the valve lash. Bring it to a dealer and let them service it
Sat Dec 24, 2011 11:41 pm |
hunterg
thanks man
Sun Dec 25, 2011 12:03 am |
Mudhead
Did you check to make sure the choke hadn't worked its way out? Happened to me last time out and I couldn't figure out what was going on until I got back to the dock...
...then felt like an idiot
_________________ Geaux 1848, 32PD w/stage III case gasket and decked valve covers
Sun Dec 25, 2011 6:57 pm |
duckhunter888
Joined: Wed Jan 14, 2009 10:44 pm Posts: 828 Location: North Texas
Check all your fuel line connections. You may have an air leak. If you are using quick disconnects gets rid of them.
_________________ Crisis defines character
Sun Dec 25, 2011 7:57 pm |
OwenDickeson
Sun Dec 25, 2011 9:48 pm |
WestEndAngler
MMT Moderator
Joined: Thu Mar 05, 2009 9:11 am Posts: 9143 Location: Houston | Surfside
Did you take a spray from a wave????
If so your spark plug boots probably started grounding out on the motor....
_________________ GTB 1860 w/ 2019 GTR40XD-HO
Sun Dec 25, 2011 9:50 pm |
hunterg
the choke was the first thing i checked and it was fine. as for the fuel lines, i do have a quick connect at the gas tank. i'll check that out tomorrow and see if that helps. and i did check the spark plugs and changed them just in case with 2 new ones.
ill check the fuel lines tomorrow on my hunt and if that doesnt help, i'll go get it serviced.
Sun Dec 25, 2011 11:44 pm |
WestEndAngler
MMT Moderator
Tue Dec 27, 2011 2:21 pm |
