It is currently Sat Jul 12, 2025 6:09 pm
Reply to topic  [ 20 posts ]
 Prodrive Cavitation Plate.
Post Prodrive Cavitation Plate.
Has anyone tried it with the plate removed? any results...
seems like to me it hurts the performance in pure mud...not sure but curious. I know the gatortails do a little better in pure mud due to it being able to get deeper, but it seems the cavitaion plate on the prodrive doesnt allow the mud to fill back in on top the prop...
lets hear it...
Sun Feb 12, 2012 5:32 pm
Post Re: Prodrive Cavitation Plate.
Search it. Mine is shaved
Sun Feb 12, 2012 5:36 pm
tried it,,,didnt get anything..
let me try again.....i guess no good results..
Sun Feb 12, 2012 5:38 pm
Acknowledging your problem is the first step...
I do have a solution to your problem though.
Whenever you get tired of searching for the answer, let me know.
Sun Feb 12, 2012 5:40 pm
viewtopic.php?f=41&t=21193&hilit=+Duckduckboom
Airboat is the answer Craig :D
Sun Feb 12, 2012 5:41 pm
ima have to try it, cause it seems to me that is a lot of the problem...i was always able to get out of what i got into, but it sure seems that the damn cavitation plate does more harm then good! ima have to call prodrive and see what they think or why they put them on...
i would think there has to be a reason besides to keep you from cutting a hole in ya boat in reverse....but maybe not, maybe it will improve the mud performance...
im not asking for the same performance as the longer gator tails, or mudbuddies but it sure seems like it would help.
Sun Feb 12, 2012 5:48 pm
where you out in monteguet today?
Sun Feb 12, 2012 5:49 pm
The prop is the problem.
There was a guy here that had his own props made...night and day difference in the mud. But still not as good as that of the almighty...
Sun Feb 12, 2012 5:51 pm
no i wasnt i had to work today,,if not i would have been! i know with the north wind they must have had nothing but mudflats...
Sun Feb 12, 2012 5:53 pm
Check out the vids we posted in the video forum.
Sun Feb 12, 2012 5:54 pm
17x48 X-series w/ 36 prodrive hyd trim & manual fpr
Sun Feb 12, 2012 6:30 pm
I never provided the answer. Good try though.
I see your skills at being clever are honed to the same razor sharp perfection as that of your ability to choose the more dominant mud-motor.
Sun Feb 12, 2012 6:42 pm
Sun Feb 12, 2012 6:51 pm
I cut mine back a good bit more then BayouBoy did. I cut all the way to the middle bolt that holds the cav plate on. At first I did it the same amount went hunting then the same day I came home and cut it back way more. IT made a significant difference while in the MUD or real shallow. I suggest gettin this done! :D
18x54 ProDrive boat with 36 FPR ProDrive
Mikuni, MM 2x w/baffles
Wild 'n Out!! Tear'n CHIT UP!!
Mon Feb 13, 2012 7:08 am
Well...Post some pics of yours negro!!
Mon Feb 13, 2012 8:12 am
im thinking that plates gotta be a major hold back in the mud...
i know one thing, i havnt rode much in the mud but when i did i know the two motors with cavitaion plates had the most trouble! Never got stuck, but the prodrives and GDSD's didnt do so well...
so it made me think, the gdsd's have the lenght to dig a little deeper then prodrives but didnt do any better in the mud...and at least the pd could reverse and dig a little to get out....once stoped the gdsd's were done for a while...
looking at them both, they both have cavitation plates.....so im thinking this may be the major cuprit...
im choppin mines...
Mon Feb 13, 2012 8:27 am
That plate also keeps the prop from hitting the bottom of your boat when in reverse. If you remove it or make it SHORT keep in mind to check prop clearance from the bottom of the hull.
Bayou Surface Drive
337-351-0362
Tarkington, TX 77327
Mon Feb 13, 2012 10:35 am
Mon Feb 13, 2012 1:41 pm
here is the pics of the cav plate cut out I did. It helps a great deal IMO in mud and getting up in real shallow. I used a saws-all, 4" grinder and a flat/curved hand file. :D
Thu Feb 23, 2012 8:25 pm
Users browsing this forum: No registered users and 81 guests
