It is currently Sat Jul 12, 2025 6:30 pm
Reply to topic  [ 5 posts ]
 Hooking up bigger gas tank
Post Hooking up bigger gas tank
I want to hook a bigger gas tank on my 16 hp duromax. Will my carb suck fuel up ifi have a primer ball on the line or will I have to get a fuel pump?
Fri Mar 16, 2012 7:32 am
Post Re: Hooking up bigger gas tank
How far away is the tank? But i would think as long as you have a primer bulb you should be good. Does that engine have a mechanical fuel pump already?
17*38 Klibert 23GDLT
Fri Mar 16, 2012 10:34 am
If your engine is still gravity fed, then you will need to get a fuel pump as well as a primer bulb.
1846 GTB and 35 GTR
New GT Rig
Old Surface Drive Build
Fri Mar 16, 2012 11:07 am
You won't regret putting the fuel pump, trust me on this one.
1748 X-Series pushed by 36PD with MarshMellow Exhaust
Poule Deaux Crew
Fri Mar 16, 2012 11:56 am
Ya it is gravity fed. I don't know anything about a mechanical fuel pumps, like where to buy them and how to hook them up. I'm really wishing now I would have just saved up and went with a vanguard. This engine has alot of torque at low speeds but the governor in this thing is ridiculous at full throttle cut in and out enough t make you sick.
Fri Mar 16, 2012 2:10 pm
Users browsing this forum: No registered users and 103 guests
