It is currently Mon Jul 14, 2025 5:07 pm
Reply to topic  [ 15 posts ]
 This ever happen to anyone?
Post This ever happen to anyone?
So, yesterday morning my father-in-law and I are heading down the canal to make a fishing trip. After running for about 10 minutes I begin to hear a high pitched "buzz" sound coming from the motor, almost like a leaf would've been caught in the flywheel guard. When I look back to see what it could be, all of a sudden I hear a loud crash, see a few sparks, that sounded like gears were all of a sudded grinding together. I instantly kill the motor to see what the hell just happened.
Apparently the flywheel cover bolts came loose and caused it to rub the plastic around the guard (which caused strings of plastic to shear, hence the "buzz" sound). And after a matter of just seconds from first hearing the buzz, the flywheel cover jammed against the guard that sits atop the motor, shattering the blades on the flywheel itself. The only way of knowing these screws would've been loose is by taking the guard off the top the motor and checking the flywheel itself. These are the results.......
Mon May 21, 2012 8:47 am
Post Re: This ever happen to anyone?
I have heard of it happen to quite a few people actually.
Mon May 21, 2012 9:49 am
I took my mesh off. Dont need it. Just the outside gaurd is fine. Sorry to hear about that!
Mon May 21, 2012 9:59 am
Rob, on a positive note, I finally used the trolling motor for the first time on this outing and was able to land a couple limits of reds. That motor sure pulls strong and it ran great, thanks again.
35 GTR - 1754 Extreme
Mon May 21, 2012 10:16 am
Had that happen on my first stage 3
17x48 extreme stage 2 GTR
Mon May 21, 2012 10:24 am
Second mod on a MM should be this:
Mon May 21, 2012 10:57 am
Mon May 21, 2012 11:04 am
Mon May 21, 2012 12:07 pm
Mon May 21, 2012 12:10 pm
Mon May 21, 2012 12:39 pm
Just take that chit off the motor. Unless your cutting grass with it Im pretty sure you dont need a grass screen.
18x48 Charles Leonard / 36PD
Mon May 21, 2012 9:39 pm
This happened to me and Cody when we first built his MB, we were coming out of a mud hole hit a little grass bed kicked the motor up and Them studs give out when the motor hit 6500rpms, they make a horrible sound like the motor just blew up or something, you should have seen his reaction when it happened :lol: . I took my studs off cut them a 1/4 high from the threads and reinstalled them to hold the ring on. You cutt them just enough to where you can get a socket on them, you don't have to worry about them anymore. After that happened to me and cody we took mine off and cutt them.
Mon May 21, 2012 9:57 pm
Sorry it happened to you but thanks for posting it, I will be removing my "grass screen" now.
Tue May 22, 2012 4:25 am
Long time ago Gary made a post about this. I believe he removed the screen and ziptied it to the shroud. Seems like the screen would help on a pd to keep debris from falling in it especially when running in the woods and brush.
1850 & 36pd
Tue May 22, 2012 5:18 am
Tue May 22, 2012 6:20 am
Users browsing this forum: Majestic-12 [Bot] and 133 guests
