It is currently Mon Jul 14, 2025 5:08 pm
[ 6 posts ] |
willtodo
Joined: Tue Jan 27, 2009 9:51 pm Posts: 142 Location: EAST TX.
 23hp surge up & down
got a brand new 23 van,,,at full throttle it surges up and down,,, i havent hooked up tinny tac yet so im not sure what the rmps are ,, but im relativly sure its going to be in the 3600 nieghborhood,,the linkage works back in forth on its own at the carb,, is this the governer if so how do u fix,,,,
_________________ off the streets and on the creeks 15/42 crawdad 23 swomp
Sat May 26, 2012 12:12 pm |
sftull
Joined: Tue Mar 08, 2011 1:33 pm Posts: 601 Location: Rock Hill, SC
 Re: 23hp surge up & down
That is the gov. You need to bypass it. Look at the BPS or SETX performance sites. I believe they have a kit.
_________________ 1846 GTB and 35 GTR
New GT Rig
Old Surface Drive Build
Sat May 26, 2012 7:13 pm |
Puddle jumper
Joined: Fri Jan 20, 2012 11:56 pm Posts: 98 Location: Abita Springs, LA
Thats running wide open in or out of the water?, should go away when under a load or the idle spring on the gov. doesnt have enough tension. The idle spring will change your overall rpm so I wouldnt play with it till the tach's installed.
Sat May 26, 2012 7:43 pm |
willtodo
out of water
Sat May 26, 2012 7:46 pm |
Team Camo
Joined: Thu Oct 01, 2009 4:49 pm Posts: 8536 Location: Bridge City, TX
_________________ 1846 GTB & 35 GTR Team Gator-Tail
Killer Kallz & ANGLE PORT dealer (409) 720-8949
Sat May 26, 2012 8:26 pm |
willtodo
willdo
Sun May 27, 2012 3:05 pm |
[ 6 posts ] |
Users browsing this forum: Majestic-12 [Bot] and 133 guests |
