Dragginaknee
Joined: Mon May 07, 2012 12:21 am Posts: 117 Location: Madisonville, La
 MM engines with reverse?
I was originally looks at the Gator tail motor with reverse because of the instant reverse. Then after hearing that it doesn't have much power in reverse (standing on dock you could hold the boat in place while someone had it full power in reverse the boat wouldn't move until the guy on the dock let go). Not sure how true this is. Then I considered the pro drive w/ full power reverese. I am now leaning to the mud buddy motor because for close to the same price for reverse I can get a bigger motor. My question is for those that have reverse, how often does it come in handy, and if you had to do it all over again would you still get reverse?
Mon Jun 11, 2012 11:15 pm |
Team Camo
Joined: Thu Oct 01, 2009 4:49 pm Posts: 8536 Location: Bridge City, TX
 Re: MM engines with reverse?
As a guy who always said "I don't need reverse," I find myself using it constantly. As far as the guy standing on the dock holding the boat in place, tell him to come grab my bow & show me. I promise you, he's gettin wet or lettin go.
As for the PD vs GT vs MB decision, only 2 of these motors are actually in production & can be obtained in a reasonable time frame. The other hasn't been released to the public yet, but he'll gladly take your deposit & maybe get you a motor produced sometime in 2012. Go test drive them & decide for yourself which motor best suits your needs & is more convenient for your daily use.
_________________ 1846 GTB & 35 GTR Team Gator-Tail
Killer Kallz & ANGLE PORT dealer (409) 720-8949
Mon Jun 11, 2012 11:24 pm |
Dragginaknee
Thanks man! So your happy with your gtr? If u get stuck going forward does the reverse work in getting you unstuck by going in reverse? I thought that's what I wanted originally until I went and priced out a gator trax today
Mon Jun 11, 2012 11:35 pm |
cb5331
His opinion was purchased.
Mon Jun 11, 2012 11:39 pm |
Team Camo
Not completely purchased, dic. As for getting unstuck with reverse, doesn't matter which one you get, if you're stuck bad enough, you're stuck. PD is obviously a stronger reverse, because the prop is spinning in the diection it's meant to, vs spinning in reverse motion. The down side is that it takes a few seconds to put the motor in reverse, whereas you get instant reverse with a GTR.
Mon Jun 11, 2012 11:45 pm |
cb5331
Rah rah rah, blah blah blah
Mon Jun 11, 2012 11:49 pm |
Dragginaknee
Mon Jun 11, 2012 11:53 pm |
take'emgator
Joined: Mon Oct 19, 2009 6:38 pm Posts: 10201 Location: SETX
As far as the guy holding on too the bow i would have to agree with Camo on that one, let him hold on to my bow, he'll for sure get wet. While not as strong as the prodrive reverse they are a little more user friendly and can get you out of a bind. Just a little backward forward motion dig yourself a hole and the GTR will come right on out
Tue Jun 12, 2012 1:47 am |
Will
Take your time, test drive them both, they are both good machines.
_________________ Before the internet, the majority of the village idiots stayed in their villages.
Tue Jun 12, 2012 3:58 am |
woodysqueal23
The GTR reverse is not as powerful as the prodrive, no argument there. But it is adequate to get you unstuck. It pulls better in the mud than in deep water. Like Camo said, if u STUCK, sometimes a freight train cant get u out!
Tue Jun 12, 2012 7:20 am |
cb5331
Tue Jun 12, 2012 10:47 am |
cb5331
Will gave the only correct answer to your question, btw.
Tue Jun 12, 2012 10:49 am |
Team Camo
Will said the same thing I did, dumbass!!!!
Tue Jun 12, 2012 11:11 am |
cb5331
Yeah, but you said a bunch of other shit, hard to decipher through all the gurgling.  Will said all that needed to be said.
Tue Jun 12, 2012 11:33 am |
deltaduckmaster
What all the videos from the video gallery !! If you want to see side by side comparisons on reverses go watch my utube videos their under deltaduckmaster!! Buff said!!
_________________ 17x48 extreme stage 2 GTR 20X60 DUAL RIG BOWFISHING ADDITION http://www.scalesandtailsbowfishing.com
Tue Jun 12, 2012 11:48 am |
Robn1020
Joined: Mon Feb 16, 2009 6:09 pm Posts: 4232 Location: Cypress, TX
Tue Jun 12, 2012 11:53 am |
swampbilly
Joined: Fri Oct 07, 2011 6:08 pm Posts: 1054 Location: Dam-b, Texas
i have recently been introduced to the gatortail and the instant reverse is awesome! however if you wanna back up more than 2 or 3 feet it's a pain in the dick. i was in a situation a few weeks ago where i had run a ditch that was a almost as wide as my boat and then it ended a 1/4 mile in the marsh and had to back out the whole way. a gatortail would of made it out, but it woulda took a hell of a lot longer to do it.
_________________ pd36 fpr 1754 cc rig
Tue Jun 12, 2012 12:00 pm |
WestEndAngler
MMT Moderator
swampbilly
Tue Jun 12, 2012 12:02 pm |
Team Camo
"husky"
Tue Jun 12, 2012 12:10 pm |
Woodiebuster
Here is my opinion on the deal.
GTR reverse is very much a convenience although it can get you out of some places, if I was frogging, running nets, or had a set run down a shallow trail every day to my blinds and could use the instant reverse to back in and out of the blinds/chase cripples GTR would be the motor to own.
One place I've seen GTR's struggle where a PD doesn't do bad is reversing in thick grass, a prop pulling backwards with no raked skeg to deflect grass will build up a ball of the stuff around the transom and eventually stop you. A PD can get up on top of this by lifting the transom up out of the water and pushing it all under the boat.
It's really a no-brainer, test them both in the places that you will use them
Tue Jun 12, 2012 12:34 pm |
woodysqueal23
Its going forward in a prodrive in thick grass thats the problem. both will run across the top just fine but idling through it frogging is a whole nother story. My brother in law and i frog together twice a week , he has a prodrive I have a gtr. GTR is a waaaay better frogging motor hands down, we both agree on that.
Tue Jun 12, 2012 12:50 pm |
woodysqueal23
But yes WB, they do plug up with grass in reverse pretty bad. I think i may build a dual rig with one GTR and one prodrive. use the GTR for idling forward and the prodrive for reverse!
Tue Jun 12, 2012 12:52 pm |
deltaduckmaster
In every situation Gtr dominate a Pd !!plain and simple!!
Tue Jun 12, 2012 1:10 pm |
woodysqueal23
I like them both. I own a GTR and would definately not say EVERY situation GTR is better. GO down a canal as wide as the boat with high banks that u cant turn around and tell me FPR wouldnt be better.
Tue Jun 12, 2012 2:35 pm |
deltaduckmaster
Ok Pd's fpr is way better than their forward!!
Tue Jun 12, 2012 2:37 pm |
deltaduckmaster
Tue Jun 12, 2012 2:39 pm |
Woodiebuster
There are video's you made of yourself where the GTR is getting either mud or grass so wraped up around the transom and belt housing it stops you.
Tue Jun 12, 2012 5:28 pm |
deltaduckmaster
Tue Jun 12, 2012 5:36 pm |
Podcast
Joined: Fri Dec 09, 2011 12:33 pm Posts: 1363 Location: Friggin cold up here
I've seen em all get clogged with grass at low speeds. Gotta open em up ta get it off. Like stated above, there ain't a way I'd go 300 yards up a slough that ya can't turn yer boat around in and not have FPR. The under water weeds in the Horicon and other marshes up here are WAY too thick ta have a standard reverse rotational prop power through it.
_________________ Wildberry "Between You, Will, DUCK HEARSE, and PODCAST I have trouble reading anything on here" 23GTR stage 2 by Calen pushin a 1746 Kliebert
Tue Jun 12, 2012 6:44 pm |
JIMMY W
Joined: Tue Jan 13, 2009 8:02 pm Posts: 4534 Location: South Louisiana
you just need a little more stick time!!
_________________ 17/54 GT EXTREME Center Console, Huntdeck w/ GTR 35
Tue Jun 12, 2012 6:53 pm |
Woodiebuster
I was outside awhile ago messing with my boat and said "I sure wish I could see things like DDM does"
BAM!!!! Lightning struck and cut my boat in half! Now I understand clearly! GTR's are best cause he said so!!!!
And I don't even have to hit the exclamation marks anymore!!! It does that on its own!!!!
Tue Jun 12, 2012 6:57 pm |
tchauvin
Joined: Wed Jul 13, 2011 6:23 pm Posts: 4898 Location: Bourg LA
i can tell you this,,,without it. Doing shit as simple as froggin i found myself not only using it...but needing it...
i would have been screwed for a while with only forward. If you dont have it, you better keep some hip waders in your boat cause you will end up pushing for sure. No matter what one you get the reverse will help you get out of a bind much more easy...
Tue Jun 12, 2012 7:04 pm |
CAJUN OUTLAW
cammo and takem,if yall gtr throws that much water in reverse that it will wet the guy on the dock then yall should look into one of them reversin plates! wow i thought mine was bad,it only wets me and any passengers sittin on the back bench. just kiddin
Tue Jun 12, 2012 7:07 pm |
Team Camo
Mine makes everyone around wet
Tue Jun 12, 2012 7:28 pm |
POKER1
Joined: Tue Jan 13, 2009 8:02 pm Posts: 6243 Location: Bossier City
You wont hold a GTR rig and keep it from backing up thats for sure. They back up just fine. However in Terry's wildest dream its still not FPR.  If you buy into the fact that you dont need reverse then you kidding yourself. And the most important fact to keep in mind at this time is MB is not selling a reverse at this point. And their track record is if they say coming in September, they mean 2014.............
_________________ 18x48 Charles Leonard / 36PD
Tue Jun 12, 2012 7:45 pm |
