It is currently Wed Jul 16, 2025 9:59 am
[ 5 posts ] |
Kill Switch for Honda clone
FRANKtheTAU
Joined: Thu Dec 29, 2011 10:30 pm Posts: 1386 Location: West TN
I've searched and searched but can't answer my question. I've got a GX390 clone with electric start and I'm looking to wire up an emergency kill switch. I'm looking at a model that has only two wires. It says it's normally a closed circuit and when the lanyard is pulled, the circuit is opened and the motor is killed. Can anyone tell me how I need to wire this up? Thanks guys.
_________________ 40 Backwater SWOMP Lite / 1752 Alweld Mud
Sat Jun 23, 2012 1:37 am |
FRANKtheTAU
 Re: Kill Switch for Honda clone
Does anyone have any ideas? I can't find anything definitive about how to wire up this kill switch. It says (closed circuit to run) and there are two wires. Can anyone offer up a solution? I'd sure enough appreciate it! Thanks guys!
Tue Jun 26, 2012 12:25 am |
ironman_gq
Diconnect the kill switch (unplug it) and see if the engine starts, If it does, take a paper clip or wire and stick it in the wire coming from the coil and touch it to ground, if the motor dies you have a "normally open" kill switch and it works by grounding out the coil, If it wont start to begin with you have an NC kill switch. They make lanyard kill switches for both style, you just need to look around for them.
Wed Jun 27, 2012 2:32 pm |
garjacker
Joined: Sat Oct 17, 2009 3:39 pm Posts: 321 Location: greensboro n.c.
they run with a normally open kill switch. when your switch is at the off position it is closed and grounded. chase the wires from the switch and one should run to a mercury tilt switch and a low oil sensor. these all tie together, this is the terminal kill. the only other ones you will have on most clones will be a wire to your chargeing circuit,that ties to the start solinoid then back to the battery and a common ground wire, usually tied to the switch housing.
Thu Jun 28, 2012 5:33 pm |
brianb
Joined: Mon Nov 29, 2010 6:02 pm Posts: 534 Location: louisiana
if you can locate the wire that comes off the top of the block under the gas tank, it comes out on the same side the starter is on, tap into this wire with a switch that is Open when the lanyard is connected and your other wire from the switch goes to ground. The wire from under the gas tank (if yours has it) grounds the coil out
_________________ gtr35 gt 1854 / w gatorglide 12 ft 11hp longtail 14 ft 10 hp longtail Merc 225hp TR20
Thu Jun 28, 2012 8:47 pm |
[ 5 posts ] |
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 95 guests |
