It is currently Fri Jul 18, 2025 4:41 pm
Reply to topic  [ 19 posts ]
 What would you all recommend to mod up my motor
Post What would you all recommend to mod up my motor
I have 31hp mudbuddy. I am not the most mechanically inclined so was wondering what were some of your opinions for mod my motor???????
Thu Jun 28, 2012 5:36 pm
Post Re: What would you all recommend to mod up my motor
Not being mechanically inclinded, I'd start with carb and exhaust. Both are fairly simple bolt ons.
Thu Jun 28, 2012 5:47 pm
I'd get a 35 carb, cam, heads, and exhaust.
Thu Jun 28, 2012 6:11 pm
Just curious what length outdrive is that
Sent from my C771 using Tapatalk 2
17x50hd gator trax 45mag mb
Thu Jun 28, 2012 7:35 pm
Not sure where u measure tron but the back belt housing to the end of prop 42 from grease housing to b4 prop 35 and to end 39
Thu Jun 28, 2012 8:09 pm
Im building a 31 right now cody has.my heads doing carb exhaust cam and setx heads ill let u.know how t runs did 26 with 2 people light load before trying to get 30 - 32 with an ok.load
Fri Jun 29, 2012 6:30 am
i started with single carb and crossover exhaust ...... what big difference so far . thats apretty good starting point and anyone can put these on themselves
Fri Jun 29, 2012 8:41 am
1854 Brother pulling a 36 PD
viewtopic.php?f=5&t=12825
Fri Jun 29, 2012 10:22 am
lefty loosey, righty tighty.
A cam swap is the same concept as anything else :lol:
Its not like you have to grind the cam out of a stone, just align the timing marks. :mrgreen:
Fri Jun 29, 2012 10:29 am
Woodie, you left out pistons and rods. If you're gonna do it, do it right.
Fri Jun 29, 2012 10:31 am
your right, if he has the heads and the crankcase cover off, he might as well unbolt all of four bolts on the rod caps and replace that too.
Fri Jun 29, 2012 10:33 am
A good pair of mods to start with is a plutonium powered flux capacitor and a nitroglycerin fueled carb.
Fri Jun 29, 2012 10:40 am
If you know what a feeler gauge is and how to use it, go with a new carb with an accelerator pump, custom heads, and open exhaust. Adjusting the valves is really the only technical part and it's easy if you use the right technic.
Fri Jun 29, 2012 10:58 am
Fri Jun 29, 2012 11:31 am
Fri Jun 29, 2012 11:46 am
replace the frame with a surface drive frame, which is about 3500$, and also cheaper than fully modding your motor :)
But on a more serious note, carb, exhaust, and heads.. the heads arent too tricky you can youtube the crap out of how to adjust valves and figure it out.
Sat Jun 30, 2012 1:27 am
GTR, Waitin' on a DFOU hull
Sat Jun 30, 2012 2:39 am
looked like a longtail on my phone screen- I was so sure of it I had to pull a pic of it up on my computer!
Sat Jun 30, 2012 10:04 am
Thanks everyone for all the comments and helpful info
Sun Jul 01, 2012 10:49 am
Users browsing this forum: No registered users and 152 guests
