SouthernWake
 Dumbest Question
I feel like an idiot. I just got my new engine today got everything ready no problems except; I cannot get the protective nut at the end of the drive shaft off? Any advice? I know already, I feel dumb enough asking. It seems to be on there pretty tight and the shaft wont lock in to get any torque. I'm sure its something simple I'm missing.
Thu Jul 19, 2012 5:29 pm |
SCmudder7071
 Re: Dumbest Question
Are you referring to just a motor? Or a whole package ie, engine, frame, prop etc?
_________________ 1754 Extreme/LAProp Stage 2 GTR
Thu Jul 19, 2012 6:53 pm |
SouthernWake
Just a motor, it's the larger duramax from maxtool if that helps. I can't connect to the u joint until I get this bolt off.
Thu Jul 19, 2012 6:57 pm |
Goose Crumpler
Joined: Thu Dec 02, 2010 9:51 am Posts: 1404 Location: Northern Wisconsin
Pictures really help
Thu Jul 19, 2012 7:19 pm |
SouthernWake
I'll try to take some pictures when I get home but I'll try to explain it again until the . The part that inserts into the u joint on the longtail (shaft that comes out of the engine that spins)has a bolt and washer that goes into it to protect the threading while shipping.
Thu Jul 19, 2012 7:38 pm |
richard nagon
left hand threads ? righty loosey lefty tighty
_________________ JUST ANOTHER FARMER ON WELFARE
Thu Jul 19, 2012 7:43 pm |
SouthernWake
That's what I was thinking but it's not coming off maybe it was torqued on too tIght? How do I get the shaft to lock up or get a grip on it? Channel locks aren't doing it.
Thu Jul 19, 2012 8:17 pm |
SCmudder7071
Impact wrench
Thu Jul 19, 2012 8:32 pm |
Bayoublackhunter
Joined: Sat Oct 02, 2010 4:55 pm Posts: 1192 Location: BAYOU BLACK
_________________ 35gtr on a 1854 Deep South Custom 1436 flat pushed by a 16 GDLT
Thu Jul 19, 2012 9:11 pm |
SouthernWake
Impact wrench would have done it but brute force a pipe wrench and channel locks just pulled through. Thanks!
Thu Jul 19, 2012 9:14 pm |
MALLARDSX2
Joined: Wed Jan 28, 2009 6:34 pm Posts: 978 Location: GA
If you dont have an impact wrench put a piece of wood under the prop and use a breaker bar....It will come off then...seen myself do it!
Mon Jul 23, 2012 6:15 am |
