It is currently Fri Jul 18, 2025 5:50 am
Reply to topic  [ 14 posts ]
 gt trim unit
Post gt trim unit
I took the black cap off the of front the unit an touched two wires straight from a battery to directly to each side of the electric motor an the the hydraulic ram moves in an put but it doesn't work with the cap on. I checked an I have power to the parts in the black cap just not understanding why it won't work any help is appreciated
16x44 Hanko Skiff
35GTR
Sat Sep 01, 2012 8:56 pm
Post Re: gt trim unit
English muthaphucker. do you speak it?
Did you test your switch?
Sat Sep 01, 2012 9:00 pm
Im testin it straight from a battery no switch involved
16x44 Hanko Skiff
35GTR
Sat Sep 01, 2012 9:10 pm
Reset the breaker. If that doesn't fix it, check to make sure you have power to the switch & relays. If you put power straight to the pump & it moved, then the pump should be good.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sat Sep 01, 2012 9:43 pm
I just figured it out it took some fine tuning. I took the black cap off were the wires run into the unit and checked to make sure the electric motor still worked an it did I had some corrosion on the wires inside that black cap cleaned em up an it works fine now
16x44 Hanko Skiff
35GTR
Sat Sep 01, 2012 9:45 pm
get some di electric grease and put it on all the connections. Not the spray kind thou
Sat Sep 01, 2012 9:59 pm
junk :lol:
Sun Sep 02, 2012 6:57 am
Sun Sep 02, 2012 10:55 am
Sun Sep 02, 2012 9:20 pm
it works by the way
16x44 Hanko Skiff
35GTR
Mon Sep 03, 2012 5:16 pm
I hear that in 2013 every GTR will come with a built in ohm meter - LOL
:lol:
Eat - Sleep - Hunt ! ! !
Mon Sep 03, 2012 6:42 pm
how old is this dude ^^
16x44 Hanko Skiff
35GTR
Mon Sep 03, 2012 6:46 pm
He still drives a GD, you do the math
Mon Sep 03, 2012 6:50 pm
there were freshman at my high school less childish than he is
16x44 Hanko Skiff
35GTR
Mon Sep 03, 2012 6:52 pm
Users browsing this forum: No registered users and 90 guests
