It is currently Thu Jul 17, 2025 6:02 pm
Reply to topic  [ 33 posts ]
 Added heads finally and lost power
Post Added heads finally and lost power
I put my IM heads on finally and am having some problems now. My throttle response is slower but it would still turn 4200 oow but I have no power. Put it in today and it wouldn't turn over 2400 rpms. Valve lash was set by Cody's way and then I tried it per Briggs by going off TDC. What is yalls opinion? Could I be pulling in air through a damaged gasket? Would it cause that? Any help is appreciated
Sun Oct 14, 2012 1:08 pm
Post Re: Added heads finally and lost power
Check the compression.
You set the valves Cody's way, and then Briggs way. How much difference was there in the lash? There really shouldn't be any. From the info you gave, I would be guessing you screwed up the lash. Hopefully you didn't damage the cam.
Sun Oct 14, 2012 1:12 pm
Did you set the valves on the compression stroke?
Don't mistake my kindness for weakness, my ability to look over things as ignorance - but make no mistake, when I've had enough, I'm Coming After you. Watch Your Back....lol
Sun Oct 14, 2012 1:16 pm
Compression test will tell of a bad head gasket and you prob would hear it
Sun Oct 14, 2012 1:18 pm
Whats the best way to check.compression? Asking because I dont have a ton of fancy tools. I set it per Codys way and when the throttle was lagging I double checked it per Briggs method. I ran the boat for at most 20 yards when I realized something wasn't right.
If the cam is damaged it'll be okay because I'll be replacing it soon
Sun Oct 14, 2012 1:20 pm
When you double checked the lash, was it spot on or did you have to change it again?
You can borrow a compression tester from your local auto parts store. Pull the spark plug, insert the fitting on the tester into the spark plug hold, hold the throttle WOT, and turn the starter until the dial quits going up. Just a few revolutions should suffice. Make sure you remove the plug and/or the plug wire on the other side before testing so the motor doesn't fire up on one cylinder.
Sun Oct 14, 2012 1:24 pm
Lash was spot on. No adjustment needed. And cool. I will do that asap. What does it sound like to you CB?
Sun Oct 14, 2012 1:29 pm
Compression test will also tell you if valves are holding. Did it backfire any?
Sun Oct 14, 2012 1:30 pm
No backfire at all. It really has me stumped on what the hell is going on.
Sun Oct 14, 2012 1:32 pm
MMT Moderator
I bet the IM heads are the problem get Cody to fix 'em
GTB 1860 w/ 2019 GTR40XD-HO
Sun Oct 14, 2012 2:02 pm
If lash was spot on, im relatively confident that part is okay.
I'd proceed with a compression check and go from there. If those numbers are bad, you'll need to do a leak down test.
Sun Oct 14, 2012 2:03 pm
Are you firing on both cylinders?
Gator Trax 1850HD/ MB 6000
Sun Oct 14, 2012 2:25 pm
Yes it is firing on both cylinders. Its idling great. Idle is set at 1100. The power just isnt there.
Sun Oct 14, 2012 2:47 pm
Had one a while back firing on both, but wouldn't run on both. Pull plug wire to see if it'll still run on one cylinder. My case ended up being blown gasket between cylinder and push rods. Couldn't hear it while running, but had no power.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sun Oct 14, 2012 3:23 pm
Same problem on mine Camo. Ran compression test on it this morning and it failed. Tore it down and found that a head gasket was damaged.
Mon Oct 15, 2012 12:44 pm
Head gasket will do it
Mon Oct 15, 2012 12:52 pm
Just came across this. Glad you go it figured out. Once you have it dialed in, let me know how it performs
[Stage 2.5]
Mon Oct 15, 2012 1:53 pm
Think of it this way, 2400rpm with one blown gasket, so now you may get 4800
Mon Oct 15, 2012 1:56 pm
When you go for round two, You need to take some sand paper and rough up the face of the cylinder a little, this will help the gasket "grab" the face. If you will notice the factory surface is very smooth and almost mirror like, not good when you want a gasket to seal.
Mon Oct 15, 2012 5:32 pm
Actually did that Will. Cleaned all the old gasket off and scuffed the surface. My next question tho is do y'all put a sealant along with the gasket. I didnt use a sealant because my step-dad said it wasn't necessary. Im asking because I dont want to pull the dang thing apart again for another simple fix.
Mon Oct 15, 2012 5:37 pm
No sealant, in fact clean it with alcohol before you put on the new gasket.
Mon Oct 15, 2012 5:49 pm
I use copper spray on the head gaskets. Don't know if that is a good idea or not, but I haven't had any issues and have done it this way on all the motors I've put together.
Mon Oct 15, 2012 6:08 pm
do not ever sand ur head or block surfaces ever. :o
JUST ANOTHER FARMER ON WELFARE
Mon Oct 15, 2012 7:52 pm
Why would that be Richard? Just curios. It wasnt a heavy sanding. Just a slight scuff. We do that on just about every surface that has a gasket on it on the equipment around the farm and vehicles.
Mon Oct 15, 2012 8:03 pm
sc. a alum head and block most call for a 30 to 50 ra finish. a finish that is hard to see with a eye. for a proper seal. by sanding the surfaces u could be putting in as high if not higher 100 ra. not good what ur are doing is intoducing a path way for gases to pass thru. u don't want a head gasket. as Will says that bites. during a heet cycle a head gasket moves causing what is called scuffing. which is normal. a high ra or sanded rough surface over time will cause a delaminating of the head gasket seal. causing a head gasket leak. i always clean the surfaces with a plastic scraper and howes lubricant to remove gasket material. never use a die grinder with a rolox pad a metal scraper or razor blade.
Mon Oct 15, 2012 8:38 pm
You do make sense. Just for clarification so I don't look like a total fool I did not use a die grinder or any highly abrasive material. I did use a 600 grit sandpaper. Thanks for the info Richard. It is nice having a forum dedicated to idiots like us who love running a lawnmower motor and constantly pushing them to the limits. Its also nice that there are some of y'all that are extremely knowledgeable about these motors
Mon Oct 15, 2012 8:50 pm
Mon Oct 15, 2012 8:52 pm
sc. i might of went over the top. :lol: but be careful dressing up a head or block surface. deep scratches cause problems down the road.
Mon Oct 15, 2012 9:08 pm
rn. I understand why you say not to scuff the surface, it makes since no doubt but that's the way I've been told on many different motors. What about the case gasket, what's the best way to "try" to fix that leaky bastard?
Tue Oct 16, 2012 4:45 am
1846 GTB and 35 GTR
New GT Rig
Old Surface Drive Build
Tue Oct 16, 2012 5:58 am
Bayou Surface Drive
337-351-0362
Tarkington, TX 77327
Tue Oct 16, 2012 7:18 am
I've got mine pulled right now bout to put in a new clutch, thought I might just dip the bottom half of the motor in a tub of silicone... :lol:
Tue Oct 16, 2012 7:21 am
Thanks for the help fellas. I put the motor back together this morning and the power is there. Now its time to eat CDMs spank new PD rig this weekend :lol:
Wed Oct 17, 2012 9:36 am
Users browsing this forum: No registered users and 132 guests
cron
