Mallards Only
Joined: Wed Jan 14, 2009 9:23 pm Posts: 404 Location: Idaho
 PD 36 surging
Hope it's OK to post this on this forum. Yesterday, while running my PD, the engine started surging at high RPMs(only above 3800). Motor was trimmed where I normally run it and it's never done this before as long as I've had a load on it. Only has about 50 hours on it. Plan to call KP tomorrow but maybe it's something stupid that I can check first.
_________________ 1860 Prodigy
| Sun Aug 02, 2009 8:14 am |
DeathMetalDukk
Joined: Sat Jun 27, 2009 11:50 pm Posts: 3777 Location: Knotts Island, North Carolina.
 Re: PD 36 surging
Sounds like ya sucked up some bugturd in the carb. Surges when it runs out of fuel, then chokes itself to stay goin, or at least that's what mine was doing.
_________________ Put yer face in the myrtles.
| Sun Aug 02, 2009 9:01 am |
deadbird8
 Re: PD 36 surging
If you have a primer bulb on it, pump it when it starts happening and see if its fuel starvation. (i.e. only happens at high RPM)
| Sun Aug 02, 2009 10:29 am |
Mallards Only
 Re: PD 36 surging
I'll try that. If that temporarily solves the problem, what's the best fix?
| Sun Aug 02, 2009 2:02 pm |
mudd
Joined: Wed Jan 14, 2009 5:44 pm Posts: 443 Location: Wisconsin
 Re: PD 36 surging
xgen just had it happen and ended up needing a 2-3 psi lift pump
_________________ THE, FIRST and ONLY MMT Member of the Year!
| Sun Aug 02, 2009 3:06 pm |
deadbird8
 Re: PD 36 surging
| Sun Aug 02, 2009 3:30 pm |
Mallards Only
 Re: PD 36 surging
| Sun Aug 02, 2009 4:14 pm |
XGEN-DUCKMAN
Joined: Fri Jan 16, 2009 3:51 pm Posts: 195 Location: BackWaters of Wisconsin
 Re: PD 36 surging
I was being told it was bad engineering (Briggs), vapor lock of some sort  , some need the xtra pump some don't............all I do know is that the pump fixed it and it is now running like a champ...............call PD they have the pumps ya need if ya need it...............check all your lines and tank connections also, could be a small air leak...........
_________________ If I can't Break it, it can't be Broke.............................
| Sun Aug 02, 2009 6:03 pm |
deadbird8
 Re: PD 36 surging
| Sun Aug 02, 2009 6:44 pm |
Mallards Only
 Re: PD 36 surging
Really? I've run it in warm weather before without issues.
| Sun Aug 02, 2009 9:07 pm |
dead animal
 Re: PD 36 surging
if u put on a vacume fuel pump instead of the pos cam driven stock pump u will solve the problem without having to deal wif a elec fuel pump.
| Sun Aug 02, 2009 9:25 pm |
Mallards Only
 Re: PD 36 surging
| Mon Aug 03, 2009 7:43 am |
LA OUTLAW
Joined: Mon Mar 02, 2009 9:25 pm Posts: 1096 Location: Morgan City
 Re: PD 36 surging
Get the e-pump and get rid of the priming bulb.....problem solved
_________________ 1754 GT EXTREME 37EFI
| Mon Aug 03, 2009 10:12 am |
deadbird8
 Re: PD 36 surging
| Mon Aug 03, 2009 10:27 am |
LA OUTLAW
 Re: PD 36 surging
| Tue Aug 04, 2009 8:25 pm |
oneneo3
Joined: Tue Jan 20, 2009 2:47 pm Posts: 42 Location: Kingwood, Tx
 Re: PD 36 surging
_________________ Git while the gitn's good...
| Wed Aug 05, 2009 11:53 am |
Brinkleydog
Joined: Tue Jan 13, 2009 5:15 pm Posts: 1361 Location: Longview, TX
 Re: PD 36 surging
http://www.mikuni.com/fs-carburetor.htmlDA is this what you where talking about??????
_________________ 20 x 54 with 9/16 bottom powered by Twin BLACK CHICKS with FPR
| Wed Aug 05, 2009 3:40 pm |
schrieverboy
Joined: Tue Jul 21, 2009 7:06 am Posts: 916 Location: South,La
 Re: PD 36 surging
briggs has alot of problems wit der coils(this is comming from a briggs mec.) when u run it for a long tiime the coil begins to heat up and stops thrown fire like it should.. itll start running like sh!t and ya rpms willl drop like it aint got fuel.. they can actually troubleshoot the coil n see if thats ya problem
_________________ 1648 w/ a 36 pd fpr on dat biatch G-14 CLASSIFIED SKIFF ON DA WAY!! Never try to educate someone who resists knowledge at all costs.
| Wed Aug 05, 2009 3:59 pm |
Quackpipe
Joined: Sun Feb 01, 2009 1:31 am Posts: 154 Location: ETEX
 Re: PD 36 surging
Just another 2 cents +/- a cent. I had this problem with my PD 36. Switched to all straight fittings,good hose, good pumpbulb,good filter,good connections and clamps,no kinked hoses. Turns out, I have one of those high dollar metal fuel tanks, the kind you can run accross if a snake was to drop off in the boat,AGAIN.  Anyhow, when I twisted the vent open(counter clockwise)I was turning it to far counterclockwise,which would choke the vent,just as if I close it(clockwise).TURN VENT COUNTERCLOCKWISE HALFWAY FOR FULL VENT, at least on the metal tanks.  Runs fine now.
_________________ 17x48 EXCELL/36PD
| Sun Aug 16, 2009 12:22 am |
POKER1
Joined: Tue Jan 13, 2009 8:02 pm Posts: 6243 Location: Bossier City
 Re: PD 36 surging
I changed an inline filter out once and had nothing but problems till I put a second filter on. I had bought 2. Something was wrong with a brand new filter. These things can be finicky for sure.
_________________ 18x48 Charles Leonard / 36PD
| Sun Aug 16, 2009 1:23 am |
