It is currently Thu Sep 18, 2025 4:33 am
Reply to topic  [ 10 posts ]
 Adapter??
Post Adapter??
I currently have a EVT intake with the Mikuni carb.... I know for a fact that I'm getting to much air the motor for the little bit of mods that I have because if I dont roll into the throttle slowly, it will have a bog that doesnt go away until I let off the throttle and then roll back into it. I want to experiment with my stock intake and an adapter. Where can I get or who can I contact to get a hold of an adapter to go from my stock intake to the Mikuni carb??
18x46GTB W/ 35GTR.....
"Sneaky Stage" sponsered in part by LiL Daddy Customs
Rated "Rahhhh"
Mon Nov 16, 2009 1:29 pm
Post Re: Adapter??
Depends on which Mikuni carb you have.. I had an adapter CnC'd and cost about $125 w/ the 3rd shift discount.. If you're using the Super BN then talk to Hoyt.. He was making them in the beginning..
"I just want silence. Jesus, it doesn't mean I don't like you. It just means right now, I like silence more."
Mon Nov 16, 2009 2:11 pm
Post Re: Adapter??
Mon Nov 16, 2009 3:49 pm
Post Re: Adapter??
Sounds like the carb needs to be adjusted?
Pro Drive m'fers
Mon Nov 16, 2009 3:51 pm
Post Re: Adapter??
Do a search for "scary fast power" they make a insert for mikuni and other carbs. It makes them act like a spread bore. They are well made and cost about 100 bucks the dirt bikers like them a lot.IT helps bottom end and mid range, If you are running a heavy load a gear change would help but you will loose top end.
You may be giving it too much or not enough from the acc pump setting.
Until I put in the scary fast plate noting helped my bottom end with the 45 mikuni,stock had a better hole shot, but no midrange .
JD
Mon Nov 16, 2009 6:14 pm
Post Re: Adapter??
I'm not fimiliar with an accelorator pump..... And how do I figure out which mikuni I'm running? 42, 45 or 48?
Rated "Rahhhh"
Mon Nov 16, 2009 9:22 pm
Post Re: Adapter??
Tue Nov 17, 2009 8:11 am
Post Re: Adapter??
Rated "Rahhhh"
Tue Nov 17, 2009 10:23 am
Post Re: Adapter??
I would take that as you don't have a tuning manual.
www.mikuni.com- HSR Tuning manual.
Tue Nov 17, 2009 1:02 pm
Post Re: Adapter??
http://www.googleisyourfriend.net/index.html
Wed Nov 18, 2009 7:01 am
