It is currently Thu Jun 26, 2025 12:03 pm
Reply to topic  [ 3 posts ]
 Fuel pump time I gues??
Post Fuel pump time I gues??
My motor wants to sputter when i first take off from idling.If I ease into the gas it will run good.My fuel filter does not have much gas in it when im running.If I slow down and idle and then try to get back on it, it will sputter then almost die before it comes back to life.Not sure if its a carb issue or just fuel pump time.I have no problems running wide open.Just looking for you guys thoughts.
17'6x48 Uncle J Custom 36 MAFIA
2010 36PD Hydro trim w/FPR
MarshMellow Exhaust
I MIGHT BE WRONG BUT U NOT RIGHT
Mon Nov 30, 2009 7:57 pm
Post Re: Fuel pump time I gues??
Tue Dec 01, 2009 7:25 am
It could be that the diaphram is busted in the pump, mine did the same thing when i first got it. changed the pump. no more trouble. when i took off the old one and would push on the plunger you could hear it leaking.
Tue Dec 01, 2009 12:51 pm
Users browsing this forum: Google [Bot], treyterr567 and 162 guests
