Re: need help with motor pulley
This is for the lower gear but its similar and should help you.
http://www.allmudmotors.com/blogs/how-t ... -mud-buddyGear puller usually works well after the gear is separated from the taper lock.
If the taper lock is stuck on the shaft you can put a small wooden wedge (like the ones you use to level a door/window) in the end of the slot on the taper lock. Tap it lightly to expand the lock slightly so it will come off. Be careful if you do this, too much and you will split the taper lock.
