It is currently Thu Jun 26, 2025 12:03 pm
[ 3 posts ] |
Engine Problems Need Help
Jamie B.
First of let me start with what i am running, my motor is mikuni carb, heads port polished and decked, evt cam, and exhaust. I have a dead spot from 1/2 throttle to wide open i have to back off the throttle to let it catch up the i will pick up and run fine, so i checked the carb it seems to be right, running a 162.5 main jet the motor ran fine for 150 hrs with the mods on it. I decided to do a compression check and found the the # 1 side is 145# and the #2 is 125 and it has not been wanting to idle so i pulled the head and checked the piston and cylinder seems to be fine no excess oil on the cylinder walls and smooth as a babies bottom, I noticed that my intake valve is a little on the black side and is stying wet like it is not burning the fuel but the plug looks good. I need helps guys any suggestions.
Sat Jan 02, 2010 3:25 pm |
JD
 Re: Engine Problems Need Help
spin the fly wheel and see if the lifters come up the same. What was compression when the motor was new?
JD
Sun Jan 03, 2010 10:32 am |
Jamie B.
I didn't check compression when motors was first put together it sound like when running the number 2 cylinder has a little pop, litters seem to be fine and noticed the other day that I had oil come out of the blow off valve this is thereason I mdone the compression check, I'm starting the think that the valves are not seating I will call Doug hoffpower on Monday
Sun Jan 03, 2010 4:09 pm |
[ 3 posts ] |
Users browsing this forum: Google [Bot], treyterr567 and 162 guests |
