It is currently Thu Jun 26, 2025 12:34 pm
Reply to topic  [ 12 posts ]
 carb icing ?
MMT Moderator
Post carb icing ?
does carb icing start out right away or take time to take effect ? Friends motor ran fine one day and bad the next.
duck wacker
Mon Jan 11, 2010 11:04 am
Post Re: carb icing ?
Mine will do it after about a 2 mile wide open run.ONLY if it is cold.I just turn it off ,smoke a cig,fire it back up and run until it does it again.
Mon Jan 11, 2010 11:16 am
iso-heet!!!!!
auto parts store carry it and it works
Mon Jan 11, 2010 11:28 am
Pull the carb heat switch out all the way... ;) If I remember it was the little black square...
Seriously though, the only time I dealt with carb heat was with airplanes, and you could encounter it at 70deg while turning low (idle) RPMs.
EVT Stage 1 32PD on a 17x48PD
"I'm not a Republican because I grew up rich. I'm a Republican because I did'nt want to spend the rest of my life poor. Waiting for the goverment to rescue me."
Mike Huckabee
Mon Jan 11, 2010 12:31 pm
We have had some issues with Carb icing up North here, and it ussually happens after you have ran it awhile in the cold. There seems to be a range of temp where I see it the most. Somewhere in the 10 F to 30 F range. Anything colder or warmer than that and there is not a problem. I ussuall just turn my intake on the back of my 36 to pick up warm air coming off the pipe, and that seems to help alot.
Illowa Marine - Home of Illowa Pro-Drive and the Phowler Boat Company
Tue Jan 12, 2010 7:37 am
I was the one who was having a problem with the carb icing. At least the way y'all describe it, that must have been what was going on. Now that the temperature has moderated I'm not having a problem with the motor cutting out, but I'm not going nearly as fast even though I'm trimming it the same way or at least am getting the same rpm's wutg the same weight load as what used to run the fastest. Does the carb icing have any residual effect?
Fri Jan 15, 2010 2:58 pm
Stu up here in AK has come up with a nifty attachment for the air cleaner intake for the Briggs to pull warm air off the muffler. Works pretty well and a lot cheaper than the setup Briggs sells for carb iceing .
And the ambient temp doesnt have to be below 32F to get carb icing - venturi effect
Sat Jan 16, 2010 11:32 pm
Jack Daniels Elite Pro-Staff
Sun Jan 17, 2010 1:34 am
Sun Jan 17, 2010 7:02 am
dadgum that sounded smart.....you been hangin' with Sanders?
I've had my carb ice within a mile
Sun Jan 17, 2010 8:44 am
:mrgreen: Next week's lesson we'll explore integrated isenthalpic effects of isothermic coefficients and how it effects load carrying ability. :lol:
Sun Jan 17, 2010 8:50 am
call your dealer or KP @ PD your unit is still under warranty
Sun Jan 17, 2010 6:46 pm
Users browsing this forum: No registered users and 137 guests
