the muffler only causes serious problems for the horizontal engines... the worst problem you'll have is it may rust a little on you. If the baffles do come loose the pieces won't end up in da cylinder like da horizontals, just get it replaced under warranty if it's within that timeframe.
As far as turnin da prop by hand.... u talkin about with clutch engaged or in neutral? even with da clutch engaged u can turn it by hand if u put out enough. Don't know why you couldn't at first and now u can.... been laid recently?
Welcome to da site!
