Sonny13
Shaved Heads
Looking into doin a head job on my 32 PD. How much should I deck the heads and what is the right amount of valve shim to go along with decking of Heads. Also, 3 angle or 5 angle valve job. Pros/ Cons of each. Port and polish is a no brainer.
_________________ 1648 PD 32pd
Sun Jan 10, 2010 7:45 pm |
bjg
Joined: Thu Jan 15, 2009 7:34 pm Posts: 882 Location: Ahead of you, with a rubber band turning my prop!!
Re: Shaved Heads
.50 to .60 3 on the valves
_________________ BUCK OFAMA
Sun Jan 10, 2010 8:59 pm |
MaXXis85
Re: Shaved Heads
Mon Jan 11, 2010 8:58 am |
coondik
Re: Shaved Heads
i go .060, 3-angle valve job, and a light port / polish (just knock the corners out & open up the throat a hair).
Mon Jan 11, 2010 9:30 am |
MaXXis85
Re: Shaved Heads
Mon Jan 11, 2010 9:46 am |
coondik
Re: Shaved Heads
Mon Jan 11, 2010 9:48 am |
bjg
Re: Shaved Heads
Mon Jan 11, 2010 6:15 pm |
Sonny13
Re: Shaved Heads
Mon Jan 11, 2010 8:06 pm |
coondik
Re: Shaved Heads
Tue Jan 12, 2010 7:16 am |
MaXXis85
Re: Shaved Heads
Tue Jan 12, 2010 7:44 am |
Pooh Bear
Joined: Wed Jan 14, 2009 10:43 pm Posts: 612 Location: Everywhere.USA
Re: Shaved Heads
_________________ Don't mistake my kindness for weakness, my ability to look over things as ignorance - but make no mistake, when I've had enough, I'm Coming After you. Watch Your Back....lol
Tue Jan 12, 2010 10:09 pm |
coondik
Re: Shaved Heads
Wed Jan 13, 2010 10:13 am |
Rail
Re: Shaved Heads
More importantly than just decking the heads is truing the cc's in the combustion chambers.. They should be within 1-2 cc's.. I've had a set of heads decked .070 and another set down to as little as .015 just to true them up.. My personal belief is not to go over .050 but that's just my opnion..
_________________ "I just want silence. Jesus, it doesn't mean I don't like you. It just means right now, I like silence more."
Wed Jan 13, 2010 1:41 pm |
coondik
Re: Shaved Heads
Good info. Mr. Rail Btw: have u ever seen a set of (shimmed) stock springs wear out?
Wed Jan 13, 2010 7:36 pm |
Rail
Re: Shaved Heads
Not yet but then again I haven't seen a modded motor go over about 300 hours other than RC's..
Fri Jan 15, 2010 3:36 pm |
bjg
Re: Shaved Heads
Mon Jan 18, 2010 8:49 pm |
stumpgrinder
Re: Shaved Heads
mine went 488... mostly stage 1. The last 150 or so it had a cam.
_________________ I'm your Huckleberry......... http://www.youtube.com/watch?v=XqVe3xG-wos
I am proud to be an American, I am glad that I am free... but right now I wish I was a dog, and Obama was a tree.
Mon Jan 18, 2010 8:57 pm |
deltaduckmaster
Re: Shaved Heads
My old motor is their or a little past 300!! Its crawfishing now so we shall see!!
_________________ 17x48 extreme stage 2 GTR 20X60 DUAL RIG BOWFISHING ADDITION http://www.scalesandtailsbowfishing.com
Mon Jan 18, 2010 9:00 pm |
bjg
Re: Shaved Heads
Mon Feb 01, 2010 8:05 pm |
deadbird8
My Heads Hurt- Re: Shaved Heads
xxx
Tue Feb 02, 2010 6:52 pm |
Mitschke
Re: Shaved Heads
Those deep swirls are just really rough cuts. When they mill them, its probably from them taking deep passes off the head. In other words, they might have taken 3 passes. Each pass at .020 therefore leaving a rough finish.
In order to not have that happen they just have to have the last pass only removing .005 for a nice surface finish.
Tue Feb 02, 2010 11:59 pm |
MaXXis85
Re: Shaved Heads
Wed Feb 03, 2010 9:37 am |
JpEater
Joined: Tue Sep 22, 2009 8:02 pm Posts: 245 Location: Augusta, Ga.
Re: Shaved Heads
Hey DB8 are those some EVT heads? I see the engraving. If so that is some pretty crappy quality coming out of their shop. I agree as well that too much was cut on the last pass.
_________________ Aucoin 18'x48'' Bateau, 30hp GD Longtail.
Wed Feb 03, 2010 11:38 am |
drake1
Re: Shaved Heads
Those were heads that were done when we first got started. Since then we have new equipment for decking the heads. All of the heads that were done by us were decked on a slight angle to try and help increase the flow. So you will not find a set that are truley flat.
Wed Feb 03, 2010 1:49 pm |
sea-n-spots
Joined: Wed Jul 15, 2009 4:50 pm Posts: 75 Location: La
Re: Shaved Heads
The "deep" groove finish is from the feed speed too fast, and if not using a carbide insert, the radius of the tool cutting point is too sharp. Also note the method of machining was with a lathe due to the cylindral concentric pattern.
The other pictures that illustrates a nice finish, was cut in a mill and the cutting head more than likely a multi tool, due to the "cross hatching" finish.
Note this is my opinion based on the pictures, and being a millwright for 27 years, but by no means a FE!
_________________ 1648 PD w/36FPR
Wed Feb 03, 2010 4:53 pm |
drake1
Re: Shaved Heads
Correct. New machine we have is a mill.
Wed Feb 03, 2010 5:53 pm |
Mitschke
Re: Shaved Heads
Wed Feb 03, 2010 9:39 pm |
anotherred
Re: Shaved Heads
Lathe
Wed Feb 03, 2010 10:45 pm |
drake1
Re: Shaved Heads
file and sandpaper No really a large lathe.
Thu Feb 04, 2010 6:32 am |
coondik
Re: Shaved Heads
Thu Feb 04, 2010 6:50 am |
JD
Re: Shaved Heads
Thu Feb 04, 2010 7:28 am |
drake1
Re: Shaved Heads
No JD we use a wire wheel for that. Rods and pistons are exact however the cylinders and cranks are not. Carry on.
Thu Feb 04, 2010 8:16 am |
