It is currently Sat Jun 28, 2025 8:03 pm
[ 7 posts ] |
fowl habbit
Joined: Sat Jan 16, 2010 1:52 pm Posts: 1130 Location: THE ONE AND ONLY BUFFALO COUNTY
 Gaskets
Is their anywhere else I can get new gaskets for my 35 besides through Mud Buddy. I need 2 upper head Gaskets 2 intake gaskets 2 intake cover gaskets. Im getting my heads back from the shop in town tuesday or wednesday so I would like to get them ASAP
Fri Mar 12, 2010 4:24 pm |
bayouboy
 Re: Gaskets
Jacks small engines. not sure on the part #'s. Someone on here might have em. You'll need the engine model # off the side your block by the oil filter. it should be 6 digits and start with 613... and the type (example 0110-E1) http://www.jackssmallengines.com/help.cfm
Fri Mar 12, 2010 4:33 pm |
fowl habbit
 Re: Gaskets
Ok Ill try that thanks
Fri Mar 12, 2010 4:51 pm |
Pooh Bear
Joined: Wed Jan 14, 2009 10:43 pm Posts: 612 Location: Everywhere.USA
 Re: Gaskets
only order 1 valve gasket set,it comes with 2 of everything. I made the mistake and ordered 2 sets for Benelliman,so we now have 4 of everything. The set only cost $31.68 a peice from Jacks.Your model number should be 613477-0121-e1. Your valve gasket set part number is 841123 .Hope this helps.
_________________ Don't mistake my kindness for weakness, my ability to look over things as ignorance - but make no mistake, when I've had enough, I'm Coming After you. Watch Your Back....lol
Fri Mar 12, 2010 9:56 pm |
Sonny13
 Re: Gaskets
Any small engine shop that works on Briggs motors should be able to get the m next day for you.
_________________ 1648 PD 32pd
Sat Mar 13, 2010 12:18 am |
bjg
Joined: Thu Jan 15, 2009 7:34 pm Posts: 882 Location: Ahead of you, with a rubber band turning my prop!!
 Re: Gaskets
Get a entire gasket kit from briggs. It even has valve seals in it.
_________________ BUCK OFAMA
Sat Mar 13, 2010 12:26 am |
bayouboy
 Re: Gaskets
Sat Mar 13, 2010 7:04 am |
[ 7 posts ] |
Users browsing this forum: Google [Bot] and 139 guests |
