It is currently Sun Apr 12, 2026 6:03 pm
Reply to topic  [ 6 posts ]
 gtr squeeking
Post gtr squeeking
There is a mild squeak near the belt in the gear box in my gator tail while idle. Not sure if its the belt or the discs that are in there. The squeaking gets louder when I put in forward. The service mechanic said the belt was good when I had it serviced this past winter. Any suggestions on how to determine the problem? Can I spray oil on the parts in there?
Mon Jun 27, 2016 9:49 pm
Post Re: gtr squeeking
Bearings in the clutch or gear.
Mon Jun 27, 2016 10:01 pm
Planning on using boat this weekend. Can that cause a more serious problem? Is there a way to oil that?
Mon Jun 27, 2016 10:07 pm
U better check it out early tommoro and order parts. :D
Mon Jun 27, 2016 10:43 pm
Yep. Nope. Those bearings are sealed.
Tue Jun 28, 2016 5:28 am
I've had them squeak for long periods of time without failure. Don't let that stop you from using your rig. If it gets worse a new clutch is about $250 for everything.
Bayou Surface Drive
337-351-0362
Tarkington, TX 77327
Tue Jun 28, 2016 6:49 am
