It is currently Fri Apr 03, 2026 2:16 am
Reply to topic  [ 8 posts ]
 Motor cutting out
Post Motor cutting out
Ok guys I need some help from the masters on here I have a 4000 mudbuddy when I idle around or give it a little gas it's fine but when I go to get on to plane and give it throttle it cuts out and dies what's causing this and thanks for any help
36 pd pushing a aircraft carrier
Tue Aug 16, 2016 8:36 am
Post Re: Motor cutting out
If you pump the primer bulb, when it is cutting out, will it pick up and go again?
Tue Aug 16, 2016 10:18 am
No it just dies
Tue Aug 16, 2016 10:22 am
Bulb hold pressure
Tue Aug 16, 2016 10:26 am
Bump
Thu Aug 18, 2016 8:03 pm
Dirty carb.
Thu Aug 18, 2016 8:07 pm
I don't have that problem currently on my briggs, but we've got a 4 wheeler that does it regularly. Water in the carb, trash in the jets, etc.
Thu Aug 18, 2016 8:10 pm
Ok thanks
Thu Aug 18, 2016 10:00 pm
