It is currently Sun Apr 12, 2026 5:11 pm
[ 7 posts ] |
TxGiriuard
Joined: Sun Apr 10, 2016 12:08 pm Posts: 5 Location: baytown,tx
 No reverse..
My gtr 35 center consoles reverse stoped working ahead and neutral still work but when i flip to reverse nothing... I've try a new toggle that isn't the problem...any ideas? Thanks
_________________ 35 GTR pushing 18x54 extreme cc
| Sun Aug 28, 2016 10:20 am |
msm8281
Joined: Fri Oct 09, 2009 1:50 pm Posts: 9673 Location: New Iberia, La.
 Re: No reverse..
Check bolt holding reverse clutch in place.
Sent from my SAMSUNG-SM-G925A using Tapatalk
| Sun Aug 28, 2016 11:47 am |
TxGiriuard
 Re: No reverse..
To my knowledge it is but im not 100% on it...it went out while running it not that that makes a difference
| Sun Aug 28, 2016 12:08 pm |
msm8281
 Re: No reverse..
Its probably not that. It happened to me. The bolt backed out and ripped the wires out. It burnt the fuse. So if yours is still running it something else most likely.
| Sun Aug 28, 2016 5:36 pm |
TxGiriuard
 Re: No reverse..
Yea ill be callin gatortail in the am see if i cant get some help
| Sun Aug 28, 2016 10:18 pm |
MaXXis85
 Re: No reverse..
Check the voltage at the switch and reverse clutch. That will tell you mor of what is going on.
| Mon Aug 29, 2016 6:46 am |
TxGiriuard
 Re: No reverse..
Talked to hoyt at GT ended up being my ground...wasnt too drity but guess enough for it not to work
| Mon Aug 29, 2016 1:59 pm |
[ 7 posts ] |
