It is currently Tue Apr 07, 2026 4:07 pm
Reply to topic  [ 7 posts ]
 Mikuni problem
Post Mikuni problem
I have a 2014 gtr and I took it out last weekend and when it was trimmed down it would die and I would trim up and be able to drive when I got home I took carb off and cleaned it but the air filter was full of oil it was coming from the hose from the motor. Does anyone know why this is happening
Sat Sep 17, 2016 9:56 am
Post Re: Mikuni problem
make sure its not over full of oil, or have gas in the oil from needle leaking fuel into engine.
Sat Sep 17, 2016 9:59 am
As he said^^ then start thinking about poss head gasket
Sat Sep 17, 2016 12:21 pm
I'm good on oil it's coming from the box on the side of the motor and going straight to the air filter I know a little about motors but this got me.
Sun Sep 18, 2016 8:07 pm
The 'box on the side of the motor' is the breather.
Sent from my SAMSUNG-SGH-I537 using Tapatalk
Sun Sep 18, 2016 9:35 pm
This usually means you have "blowby" or excessive pressure in crankcase. Usuall causes are head gasket leaking into lifter valley , piston rings not sealing , or valve seals. Most likely would be headgasket. If you say where your from someone on here can point you to someone to get it checked out.
Sun Sep 18, 2016 9:57 pm
I'm in denham springs if anyone knows anybody around me just don't want it to be gone for too long since I deer hunt out of my boat also
Mon Sep 19, 2016 5:51 am
