It is currently Sun Apr 05, 2026 9:42 am
[ 8 posts ] |
Southern Hunter
 37EFI PD
After changing my oil yesterday I went to throw away empty oil quarts, etc. and noticed one of the plastic rings under the cap on the quart bottle was missing.....so then I started second guessing myself, "I wonder if it fell in the oil fill?" I took out a flashlight and looked but couldn't see anything, take the valve cover off....nothing at all in there and notice that the hole in the back where the oil runs is pretty darn small. I did run the engine for a few minutes before I realized the "possible" problem. The only thing I'm now wondering, is the oil system pressurized? Could the plastic ring, if it's even in there have been "sucked in"?? Once again I'm not even sure that it's in there, more than likely not, but what do you guys think, is it possible it was sucked down or does the oil just drain down from there?
| Wed Sep 28, 2016 5:32 pm |
T-Bubba
Joined: Wed Feb 18, 2009 6:43 pm Posts: 3958 Location: Centerville, La
 Re: 37EFI PD
You are over thinking.
_________________ I gave up mud motors
| Wed Sep 28, 2016 5:46 pm |
BlueShamu
Joined: Mon Feb 06, 2012 6:13 pm Posts: 5605 Location: D'town, LA
 Re: 37EFI PD
Definitely.....not going to get sucked in.
| Wed Sep 28, 2016 7:17 pm |
dead animal
 Re: 37EFI PD
plastic gonna give before metal. lol
it probly fell on the ground somewhere. I wouldn't worry about it.
| Wed Sep 28, 2016 7:32 pm |
SETx Longtail
Joined: Sun Sep 01, 2013 2:53 pm Posts: 3480 Location: Hardin County, Tx
 Re: 37EFI PD
I'd start tearing it down immediately!!!
_________________ #CFFITR
-Custom pool noodle -stage 4 water wings
| Wed Sep 28, 2016 9:12 pm |
Southern Hunter
 Re: 37EFI PD
Yea you guys are making me feel a little better about it...once I didn't see anything under the valve cover I assumed I was ok. The hole at the very back is so small, I don't think much would pass through anyway...anything that could probably wouldn't hurt much. Sometimes it's other giving you reassurance that makes it a little easier!!!
On the other hand, SETx.....your killin me bro!!
| Wed Sep 28, 2016 9:47 pm |
Southern Hunter
 37EFI PD
So nobody really answered my earlier question.....is the oil system pressurized? How exactly does it work....just curious now!
Just to say something would indeed fall in, the small hole in the bottom on the backside after you pull the valve cover off.....is it a system of tiny ports, are there any screens in there to block trash, etc.
Although the hole is verrry small....somethings would have to be minute to get into it....which I guess if it's that small to get in, it couldn't hurt much anyway....correct? Im still trying to decide what the odds are that a plastic piece/ring like I'm talking about could make it through the tiny hole under the back of where the valve cover comes off?
I guess I'm always just a "worst case scenario" thinker....so I always end up asking lots of "what ifs".
Also while researching this I notice on the Briggs site it talks about low oil shut offs, does anyone know if the 37 EFI is equipped with this?? The reason I'm wondering is I figure "worst case scenario is something gets stuck in the and possibly restricts oil flow correct?
Learning more about these damn things everyday!!! Or every time I run into an "issue"!!! Also I don't like to think of myself as crazy.....more like thorough!!! Lol
| Thu Sep 29, 2016 3:48 pm |
cb5331
 Re: 37EFI PD
There is a pump inside the crankcase that rides on the cam. There is a screen on the pickup.
| Thu Sep 29, 2016 3:55 pm |
[ 8 posts ] |
