It is currently Sun Apr 05, 2026 12:30 pm
Reply to topic  [ 11 posts ]
 gator tail transmission lube
Post gator tail transmission lube
can anyone tell me what the correct lube is for the transmission on a gtr35 2013 model, i was told when i bought the replacement transmission to use atf fluid, but videos show oil, does it matter and if so which way is best.
Thu Oct 06, 2016 11:57 am
Post Re: gator tail transmission lube
Who told you that?
Sent from my SAMSUNG-SM-G925A using Tapatalk
Thu Oct 06, 2016 12:13 pm
I use 80w90 gear oil in the planetary trans. The heavier oil helps keep the outer seal from leaking on the newer models. ATF is a sufficient lubricant for planetary gears, But being there is such a small amount that is used in there (about 2 OZ), I suggest 80w90 and be done with it. Do not use ATF...
Bayou Surface Drive
337-351-0362
Tarkington, TX 77327
Thu Oct 06, 2016 12:22 pm
i called gator tail and the rep there was the one that told me to use atf.
Thu Oct 06, 2016 3:51 pm
Thu Oct 06, 2016 3:55 pm
Thu Oct 06, 2016 4:00 pm
Hoyt made a video that's on YouTube that recommends using the same oil in the transmission that you use in the motor. Like the rest of the guys said the heavier oil will be better because it will stick to everything and lube it better
Thu Oct 06, 2016 4:15 pm
I know people say they leak, but I've been following that video and haven't had mine leak in 90 hours.
Thu Oct 06, 2016 6:50 pm
80w 90 gear oil I know hoyt said to use engine oil but over time they will start leaking a lil that's why maxxis said to use the thicker oil.
Fri Oct 07, 2016 6:43 am
1754 With Level 3 GTR
Sun Oct 16, 2016 7:17 am
10w30
Sun Oct 16, 2016 12:08 pm
